EGR Bolts Stripped...
Old May 1, 2020
StockD16's Avatar
StockD16 is an unknown quantity at this point
Hi all, 04 LX 5SPD 203K
I was planning to replace the rear cam cap because it was slightly leaking. I went to take off the 12mm nuts and they are rusted in there good. I tried using a six point socket but, when I give it enough force, it skips. I do not want to round the nut. Any advice on how I can get those nuts off? It's a tight space. I thought I could slip out the cap but, there's not enough room. I guess that's a newbie thing.. LOL.
Old May 1, 2020
antrmo's Avatar
antrmo is an unknown quantity at this point
Re: EGR Bolts Stripped...
you could let the bolt soak over night in a release fluid,like liquid wrench
is heat possible? small torch? get a turn loose, then re tighten, then a bit more loose and re tighten,, work it until it feels like it wont snap.
Old May 1, 2020
StockD16's Avatar
I soak them with PB Blaster. I will try again tomorrow morning. If they become more stripped, I will bang a 12 point 11mm socket on them and force them out. I can dremmel them out but, not sure if the bolts are replaceable. Are the bolts part of the block?
Old May 1, 2020
Colin42's Avatar
They're replaceable, just need to find the right diagram and you can order them from the dealer. Can also try welding a nut on, the heat will help break it free. Also remove as much as you can to get better access
Old May 1, 2020
BrotatoChip's Avatar
Super Moderator
I have done this a few times with other bolts. 11 mm or 7/16" is slightly bigger but still smaller than 12 mm.
Old May 2, 2020
StockD16's Avatar
I was able to get the EGR off nut..., the nuts didn't break free, the bolts did. The nuts are still on the bolts! Did I snap the bolts? Looks like I can screw the bolts back in and the EGR will clamp down fine. My question is, is there a gasket for the EGR valve? I didn't see one. I watched a video for an EGR cleaning and they didn't have a gasket either. Should I throw in RTV, or leave it as is?
Old May 2, 2020
Colin42's Avatar
Sounds like they're studs, and I'm not sure on the gasket, I would think there's supposed to be one
Old May 3, 2020
StockD16's Avatar
After inspecting the bolts, they are studs. I was able to remove the studs. The trick to not stripping the nuts is by making sure the socket is absolutely straight on the nut and PB Blaster overnight. I guess there is no gasket. I cleaned up the valve really good and swapped out the cam cap.
I appreciate everyone's help..
Old May 3, 2020
Colin42's Avatar
Just checked, looks like there is supposed to be a gasket. Someone must have been in there before. Part number is in the picture.
John Cain
Mar 27, 2017 07:21 PM
dnmacdon
Sep 6, 2016 01:01 PM
Steven Eisler
Feb 25, 2016 05:06 PM
swoody
Jan 8, 2014 10:30 PM
MikeyV
Jun 14, 2010 10:39 PM
