Missfire(Flashing CEL)
Old Mar 16, 2020
mafiaboy01's Avatar
mafiaboy01 is an unknown quantity at this point
Hey guys, hopping for some advice. I have 2001 Civic LX Manual (145k KM) that has gotten some misfire codes.
A month ago driving on the highway at cruise the car flashed the CEL a few times. No hesitation, no stuttering car was driving like normal. I check the code after the drive and had a P0302(Cyl 2 misfire) I cleared the code and put some injector cleaner and everything was great.
Fast forward to today and I was driving on the highway again at cruise and the CEL flashed again. Once again no stuttering no hesitation car drove normal. Check the codes again. This time had P0300(Random/Multiple Misfire) P0302 (Cyl 2 misfire) and P0304(Cyl 4 misfire).
The CEL never stays on and the codes are always stored as pending.
I replaced the spark plugs May of last year. I was thinking of swapping coils 1 and 2 plus swapping coils 3 and 4 to see if the missfires follow the coils.
Any suggestions would be great.
Old Mar 17, 2020
Wankenstein's Avatar
Re: Missfire(Flashing CEL)
You can try swapping coils but most likely not the issue. Try resetting the ECU by disconnecting the negative terminal from battery and turn the headlights on to discharge any residual voltage. After five minutes (headlights off) then reconnect negative terminal to battery. Start engine with all electronics (stereo, some light, etc..) off and let idle for 15 minutes. Hopefully, the code will not return.
You can check coils as shown in link: https://www.autopartswarehouse.com/b...t-a-coil-pack/
Old Mar 17, 2020
mac25's Avatar
Dr Krieger of Modification
For all 4 cylinders to fail at one time, I wouldn't be looking at single cylinder items (plugs, coils). I'd focus on what links to all four at once.
its probably not full related as far as delivery (lines, rail, pump, injectors)
I'd guess its signal related
-injector signal pulse interruption
-spark interruption
Could be a dying sensor
-MAP
-TDC
-Crank
But at this point you might want to wait for total failure, to locate the item, since only sensors from Honda are guaranteed to work.
Old Mar 17, 2020
mafiaboy01's Avatar
Thanks for the tips. I'll try to reset the ECU to see if it helps. If the CEL didn't flash I would have had no idea anything was going on. The car was at cruise under basically no load so not a common place to get knock.
If not I'll have to wait it out to see if any other codes come up.
Old Mar 18, 2020
mac25's Avatar
You can still scan for codes if the light isnt on.
There are pending codes, which dont keep the cel on.
CWMaguire
Oct 10, 2018 11:34 AM
g4384063
Jun 1, 2015 07:59 PM
skidooman
Feb 4, 2014 08:08 PM
wallaw819
Apr 16, 2008 07:38 PM
MadWheel
32
Mar 31, 2004 10:03 PM
