Engine dies at different times
Old Feb 23, 2020
Irishguy50's Avatar
Irishguy50 is an unknown quantity at this point
Question Engine dies at different times
Hoping for some guidance on this: My daughter has a 2002 Civic that occasionally dies. The engine shudders and won't accelerate. She has to stop the car, put it in park and shut it off and restart it. It then runs fine until the next time, which may be a day or two. It is a high mileage car (over 200k) but has been well maintained. The transmission was just replace with the same unit from a 2005 with 134k miles. The engine stalling issue existed prior to the transmission going out. The computer accepted the replacement trans and it is functioning as it should.
Any help or suggestions will be greatly appreciated.
Thanks!
Old Feb 23, 2020
Slumpertcivic's Avatar
Re: Engine dies at different times
Most sensor issues that will cause the engine to die would trigger the check engine light.
Does that light turn on when she first turns they key and then turn off or does it stay on?
Old Feb 23, 2020
Irishguy50's Avatar
The light comes on and stays on. Does not go out. Car recently passed e-check with the light on.
Old Feb 23, 2020
Colin42's Avatar
So what's the code?
Old Feb 23, 2020
Irishguy50's Avatar
Will have to check for the code. Not sure what it is. Thanks
Old Feb 29, 2020
Irishguy50's Avatar
Arrow Re: Engine dies at different times
Originally Posted by Colin42
So what's the code?
Was finally able to get the car checked. It has 2 codes: P0138 and P1457. Not sure what they mean. The Advance Auto guy said one of them is for an o2 sensor (down-line)
Old Feb 29, 2020
Colin42's Avatar
The downstream O2 sensor shouldn't cause the engine to shut off, it's basically just there to see if the cat is functioning. 1457 is just a small evap leak, again shouldn't cause the engine to shut off
TSSCivic
Mar 8, 2014 03:23 PM
shanksnorth
Nov 23, 2010 01:08 AM
Lynk
Jul 3, 2004 03:52 PM
SuperCivic2k1
May 23, 2002 11:14 AM
