how many oxygen sensors in my 05 civic
Old Jan 11, 2008
05simplecivic's Avatar
05simplecivic is an unknown quantity at this point
i just got my codes read at auto zone, and the code came out as p0139, says its the bank 1 sensor 2. it also says under gen. description that its before the cat.
when i looked at my sensors, i can only see two O2 sensors one before and the second one after the CAT. is there a third sensor, if so is it on the exhaust pipes somewhere? or is it on the intake pipe before it goes in the engine?
i have read a lot about this damn sensor and read a lot about the codes, but i cant see how it would be sensor 2 if the 2nd sensor is located after the CAT, when it deliberately said it was before the CAT......
any info guys i need to get this thing done, cause if its before the CAT, im probably running a rich or lean engine..... bad mileage....
Thanks Oz
Old Jan 11, 2008
ronaldo9's Avatar
Re: how many oxygen sensors in my 05 civic
I'm pretty sure you have a problem with the primary 02 sensor (pre cat). Remember those auto zone scanners are universal and may not be the exact same description as a honda specific scanner. We have 2 02 sensors. One pre cat and the secondary is on the cat converter. That is for the EX. The LX and DX may be different since your cat is on the header.
Old Jan 11, 2008
yea i believe there are only two cause i could not find another one. the first one is on the manifold the second one is after the cat or on the cat, cant get a good look at it.
is it safe to switch them and see if it tells me a different code? that is if the wiring can reach, OZ
Old Jan 11, 2008
sensor is like $150. can i just put a bolt on header in there and call it a day?
Old Jan 11, 2008
ronaldo9's Avatar
What model do you have? If you have a DX or LX if you put an aftermarket header you will lose your catalytic converter and throw a code. (There are ways to get around the code.) I would solve the CEL problem you are having before you buy a new header. There is a problem with your car so take it to a mechanic.
Old Jan 11, 2008
RHCP0801's Avatar
two.
Old Jan 11, 2008
so the code says BANK 1 SENSOR 2. The second sensor is obviously after the cat. and it cost $336 to replace by myself. damn this sucks!!!!
what to do....
1. Does this code mean that the sensor is bad or does it mean that the exhaust emission is bad? or both.....
2. if its just bad exhaust is there a way i can overide this?
Old Jan 11, 2008
greeen01civic4d's Avatar
its probably the sensor, and u can get one for cheaper from a parts store, since its not the heated sensor it shouldnt be that expensive
Old Jan 11, 2008
TRIZ's Avatar
browse through the exhaust link in my sig...
Old Jan 12, 2008
what is a heated sensor?
Old Jan 12, 2008
a just as it sounds, its heated, i believe to match engine temp, but its that simple, its just more when its heated, and only the primary is heated
Old Jan 14, 2008
ok i cant find any damn place that has them for cheap not even ebay. anyone tell me where i can get one?
Old Jan 14, 2008
RHCP0801's Avatar
spend the money and just get it, dont be cheap
Old Mar 1, 2020
aragon1301's Avatar
aragon1301 is an unknown quantity at this point
hey dude,.. i dont know where your getting 330 bucks to change an 02 sensor, i bought mine for like 50 bucks at autozone and i bought the sucket and took it off myself, it is easy to do so, the one in front is super easy and the one on the bottom is also easy, just have to jack up the car for the bottom one,.. again i spend less then 125 fo the 02 sensor and for the sucket and thats that,.. enjoy do it yourself...
Old Mar 1, 2020
Colin42's Avatar
The thread is twelve years old!
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
ezone
24
Oct 30, 2017 11:27 AM
bsmiley
Apr 27, 2015 01:27 PM
dragonsblood
Apr 27, 2015 12:28 PM
