Emissions codes
Old Jan 16, 2020
pitnut's Avatar
pitnut is an unknown quantity at this point
Talking Emissions codes
Hey, guys i just grabbed an '05 civic dx. after a bit of driving i got a check engine light, code reader came up with p0139, p0420 and p0497. i assume the first two are related to the o2 sensor and the 3rd is an evap sensor. What would be the best way to fix these? Would a new evap and 02 sensor fix this or should I do other diagnoses? I can supply any more info and appreciate any help! also the valve gasket is leaking and i have a replacement on the way.
Old Jan 16, 2020
Colin42's Avatar
Re: Emissions codes
P0420 is for the cat, but try replacing the O2 sensors first
Old Jan 16, 2020
Colin42's Avatar
Re: Emissions codes
Use OEM Denso or ntk sensors only
Old Apr 3, 2020
Spotcw's Avatar
Spotcw is an unknown quantity at this point
Re: Emissions codes
Did you fix the problem? I have P0420 code and checked catalytic converter with temp reader and it looks good; 300 degrees going in and 500 degrees coming out. I’m hoping its the 02 sensor. Let me know. PM me.
Djmixmode
Sep 3, 2018 07:40 PM
HondaCivicNY24
Dec 4, 2016 09:11 PM
Tylerb3625
Feb 17, 2015 10:03 AM
MaximaCivic
Aug 12, 2012 09:47 AM
AndrewLA
Oct 26, 2011 08:06 PM
