Cam seal plug
Old Sep 19, 2019
rnhoward's Avatar
rnhoward is an unknown quantity at this point
Cam seal plug
Why is this thing there? I've replaced it with a new one and its still leaking. Is there a better Cam plug, something that can be tightened? 2004 EX 5 speed stick
Old Sep 19, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Cam seal plug
It is for a distributor but is not needed anymore. Use an OEM plug.
Old Sep 19, 2019
Slumpertcivic's Avatar
Re: Cam seal plug
Back in the 80’s they did take advantage of the hole for a distributor, but I suspect that was simply smart engineering for a hole that “had” to exist to bore out the camshaft journals precisely.
While the need for distributors disappeared, the need for a precise camshaft fitment remained so we still have the hole.
Old Sep 19, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Cam seal plug
If OEM cap leaks then
-Remove the valve cover
-use degreaser to clean all areas needed to seal
-place a bead of liquid gasket around the head
-place the cam cap on the liquid gasket
-place a bead of liquid gasket over the top of the cap
-reinstall valve cover
-snug bolts up lightly
-Let sit overnight
-torque to spec.
Make sure not to use liquid gasket on the cam seal!
noquacks
104
May 21, 2019 06:18 PM
Justin04
Dec 27, 2017 03:00 PM
jdawgzcivic
Feb 24, 2016 01:24 PM
gack
Mar 25, 2015 08:40 AM
Carbo
Jul 20, 2013 01:41 PM
