01 civic Vtec malfunction
Old Jun 21, 2019
Steven Bui's Avatar
Steven Bui is an unknown quantity at this point
Hi guys I need help I have a 01 civic 5 speed with the 1.7 vtec motor with around 175000 miles. My car is in safe mode and I had it put on a scanner it said it was the vtec solenoid Now I replaced the solenoid did a tune up and oil change and reset the computer with a scanner and it comes out of safe mode I can rev motor to red line but as soon as I start to drive the light pops on and I can’t rev over 4000 rpms Any thoughts or advise of what should be my next step or what else could it be anywhere I call wants me to bring it in and get a dyno test done but want to charge me a arm and a leg to do so Any help would be greatly appreciated
Old Jun 21, 2019
mac25's Avatar
Dr Krieger of Modification
Re: 01 civic Vtec malfunction
Any recent modifications, replaced parts or services?
Old Jun 21, 2019
Steven Bui's Avatar
No just the vtec solenoid and tune up oil change I erased code with a scanner but when I start to drive it goes right back to safe mode
Old Jun 21, 2019
mac25's Avatar
The oil is 5w20, and it's in the safe zone on the stick, right, not high or low?
The vtec system is engine oil governed as you may know.
Also after resetting the codes with a scanner, have you tested the wires to the vtec solinoid for signal?
Old Jun 21, 2019
Steven Bui's Avatar
The oil is 5w-20 at perfect level I haven’t tested the new solenoid how would I go about doing that with a ohm reader right? I am not exactly a mechanic but I’m no dummy either
Old Jun 21, 2019
mac25's Avatar
No, if the solinoid if new, from Honda, should be fine.
You should check the wires to the solinoid from ecu, for control voltage.
Old Jun 21, 2019
Steven Bui's Avatar
Yes the solenoid was new I’ll check the wires leading to it is there a certain voltage it should read and I’ll check them get back with you I appreciate your help with this
Old Jun 21, 2019
Old Jun 22, 2019
Steven Bui's Avatar
Ok I checked the solenoid wires I am getting a reading of 12 from ecu
Old Jun 22, 2019
mac25's Avatar
The 12v was when you were driving, above 3400rpm, throttle 80%+?
You should not have voltage to the solinoid at idle. I was thinking you would test resistance from solinoid wire to solinoid exterior, and continuity from the wire from ecu yo solinoid.
I'm not 100%, but I think the circuit goes
Battery 12v+--->relays/fuses--->ecu--->vtec control wire--->grounded back to battery via vtec solinoid connection to head.
On a side note, when you replaced the solenoid, you replaced the whole unit right not just the top solinoid but the lower part of the valve? The reason I ask is just to make sure the oil screen is new or clean.
If all checks out from ecu to solinoid, then the last possibility is that some how a vtec control pin, inside the valve assembly, is stuck (possibly from carbon build up). Though this would be pretty hard to accomplish.
Old Jun 25, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
New VTEC solenoid is a Honda OEM?
camodad.17
Oct 24, 2017 07:15 PM
kamikaze999
Jul 16, 2010 11:33 AM
shawn_ashley6
May 15, 2008 08:50 PM
Island2K2
Dec 30, 2003 11:07 PM
ZSKCivic01
Sep 14, 2002 06:24 PM
