P0135 2004 Honda Civic DX
Old May 8, 2019
vstevenson's Avatar
vstevenson is an unknown quantity at this point
I am having lots of trouble resolving a P0135 code on my 2004 Honda Civic DX. There is one sensor before the catalytic converter and a second sensor immediately after. P0135 I believe refers to the O2 sensor that lies before the catalytic converter, so I replaced it, but I'm still getting the error code after resetting the ECU. I've tried several O2 sensors and keep getting the error code.
I replaced the downstream O2 sensor as well, still getting the same code.
Are both the upstream and downstream sensors O2 sensors? Some people said the upstream is an AF sensor, but I think that's the same as an O2?
Also, if the O2 sensor is good, what voltage/resistance values should I be seeing on the wiring harness in case it's an ECU problem?
Thanks!
Old May 9, 2019
Slumpertcivic's Avatar
Re: P0135 2004 Honda Civic DX
It’s a AF sensor, not the basic O2 sensor.
Some have gotten the $100ish denso direct unit to work, always the $250ish oem one works, frequently people buying generic end up on the forum because it still isn’t working..
always possible is not the sensor but a wireharness / ECU issue.
Old May 10, 2019
vstevenson's Avatar
Thanks for the info.
If it is damage to the wiring harness/ECU, do you know what voltages/ohms I should expect between the pins? I can't seem to find that info.
Camden
Oct 9, 2011 01:41 PM
ssasnds85
May 10, 2011 05:30 AM
butler89sir
Aug 7, 2010 10:13 PM
civic99whistler
Aug 23, 2009 03:46 AM
03CivicEX03
Nov 7, 2004 11:55 PM
