P1361 & p1362
Old Nov 7, 2018
ron36535's Avatar
ron36535 is an unknown quantity at this point
P1361 & p1362
I an having the same problems as others are. I have a 2002 honda civic LX. showing codes P1361 & P1362.
Had the same problem a few months back, and I changed the cam shaft sensor and all was good until last week.
what is the different symptoms of a cam shaft sensor problem and a crank shaft sensor problem.
thanks for any help given !!
Old Nov 7, 2018
mikey1's Avatar
Re: P1361 & p1362
did you replace it with a OEM honda sensor?
i have heard alot of bad stories about cheap aftermarket sensors when used on these cars,
if it is OEM sensor it could be a wiring or connection issue
Old Nov 7, 2018
ron36535's Avatar
Re: P1361 & p1362
Is not OEM.
But what is the difference between a camshaft sensor symptoms and a crankshaft sensor symptom ?
If not a wiring issue, does the P1361 & P1362 point to the cam or the crank sensor ? which is more likely ?
Again I did replace the cam sensor a few months back with one from Advance (Not OEM).
Thanks again
Old Nov 8, 2018
mikey1's Avatar
Re: P1361 & p1362
Originally Posted by ron36535
Is not OEM.
Thanks again
i would suspect the sensor bad again, and i would replace it with an OEM honda sensor,
aftermarket sensors seem to have a lot of problems in these cars
Old Nov 8, 2018
ron36535's Avatar
Re: P1361 & p1362
Can a cam sensor be bench tested? If so what would be the procedure ? Thanks again. ( Ido have it out of the car )
Old Nov 9, 2018
mikey1's Avatar
Re: P1361 & p1362
not really, but you can use process of elimination by testing all the wiring and signal to the sensor,
i had a faulty cam sensor last summer and used these instructions to determine if it was the sensor or wiring,
click the following link and use the instructions in the second post in the thread, using a voltmeter.......
https://honda-tech.com/forums/honda-...0-rpm-3081569/
Old Nov 9, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: P1361 & p1362
We have seen many posts that solve this issue using only OEM Honda sensors.
John91816cc
Oct 2, 2019 06:16 AM
mikey1
Jul 22, 2018 01:10 PM
honda.lioness
Sep 17, 2017 04:19 PM
contevo
May 8, 2015 03:49 PM
BiggieCivvie
Jan 24, 2011 05:00 PM
