2004 Honda Civic Stalling/Jerking
Old May 4, 2016
Rubberchickentm's Avatar
Rubberchickentm is an unknown quantity at this point
I have a 2004 Honda Civic LX manual transmission. I have a stalling problem that started a month or two ago. My car will stall when stopped and in neutral or very low rpms. This only happens when the engine is warm. It also has a hard time starting back up. I have to crank it and gas it to get it started. At first it happened maybe every few days but the more I drive it, the more often it stalls. If I don't drive it for a few days it doesn't stall at all. My car drives perfectly otherwise and it gets even better gas mileage than before.
I had the timing belt and water pump done in Nov.
The cel was on when it first started happening. Autozone said it was p0497. So, I started cheap, replaced spark plugs and air filter, put in an expensive fuel system cleaner and cleaned the iacv and throttle body. Didn't work.
Got it checked out at a few different places that said it could be fuel pump, crankshaft, or the transmission isn't getting enough air and that it was throwing a cylinder 3 misfire code.
Took it to a Honda dealership that couldn't find any codes or get it to stall but there was a leak in the crankshaft seal and a lean fuel mixture. Said my problem was probably that the valves weren't fitting right when they expanded when they get warm.
So, got my crankshaft seal fixed and oil pan gasket (needed that too) and had the crankshaft sensor connectors fixed (they were corroded).
Now my car started randomly bucking/jerking. Happens at any speed, the rpms just randomly drop and the car lurches. Hasn't stalled yet but like I said, it's better when I haven't driven it for a few days. So, not sure if fixing the crankshaft connectors fixed the stalling issue. If anybody has any suggestions, that would be great.
Old May 4, 2016
Re: 2004 Honda Civic Stalling/Jerking
could be related. Return to that shop?
The P0497 should be unrelated to the issue above.
Old May 5, 2016
mac25's Avatar
Dr Krieger of Modification
If it all started after the new timing belt then the timing could be off.
Old May 10, 2016
I took it back and they replaced the connector with a new one. It's not jerking anymore but it's still stalling.
Old May 10, 2016
Would it have taken a few months to start stalling if it was a timing issue?
Old May 11, 2016
Does it run poorly or just idle too low?
Idle relearn?
A few months?
Not usually, it would have been apparent immediately.
If one of those engines is (cam timing) only one tooth off it may run a little bad. Once it gets to 2 or 3 teeth out of time, the computer should shut it down at about 2 seconds. Or maybe 10 seconds, Hell I can't remember now.
Old May 11, 2016
Idle relearn?
A few months?
Yeah, got the timing done in Nov and it didn't start stalling until February. It runs absolutely great, idle and everything. Just randomly when I'm stopped and the engine is warm, the engine will just shut off. Almost like it stalled but won't make a noise or anything.
Old May 11, 2016
Sounds like it is an all new issue then.
Old May 28, 2019
Dthi's Avatar
Dthi is an unknown quantity at this point
Did you end up finding out what was wrong with it I have the exact same issue
drhawkinz
36
Sep 10, 2018 05:48 PM
Alfie17
Jul 23, 2018 06:58 PM
jessica19699
Oct 25, 2017 06:10 AM
CraigT
Aug 8, 2016 01:37 PM
natefig35
Jun 5, 2016 08:37 PM
