Lossing power when pushing the fuel pedal to the floor
Old Mar 16, 2016
Houss's Avatar
Houss is an unknown quantity at this point
I have civic 1.7 LX 2003.
When i push the fuel pedal to the max,The engine RPM never receives more than 5500 RPM, and the car speed barley accelerates.
Automatic transmission stays on the same shift and nevershift up until i remove the padel from the floor ( 3/4 of the pedal)
Any help ? Thanks
Old Mar 16, 2016
Re: Lossing power when pushing the fuel pedal to the floor
Warning lights on? Fault codes?
Engine running problem or a transmission problem?
Old Mar 17, 2016
Houss's Avatar
Hi ezone,
No warning lights and no faults code on ECU,
It acts like misfiring ! Its not a transmission problem
Old Mar 17, 2016
High mileage on the car?
RPM reaches a maximum then the engine makes more noise but power does not increase?
If you back off the gas pedal or ease into the acceleration the RPM can go higher, but if you floor the gas pedal you slow down?
Did this happen all of a sudden or was this a slow progression?
At this point, without a bunch more info and data, I might guess at an exhaust restriction (clogged cat) or an intake restriction.
SolidHollow
Oct 18, 2015 08:52 AM
96EKcivic
Oct 17, 2015 07:57 PM
Zeus99ex
Oct 17, 2015 03:20 AM
Dakker
Dec 3, 2001 06:59 PM
nickfn
Nov 30, 2001 11:13 AM
