02 Civic Lx stalling out after camshaft sensor replacement
Old Jul 1, 2021
  #61
Bnshirah69's Avatar
Bnshirah69 is an unknown quantity at this point
Re: 02 Civic Lx stalling out after camshaft sensor replacement
The shop is apparently notorious for screwing over females
Old Jul 1, 2021
  #62
FRSam's Avatar
Click Here
I've read nothing that in any way indicates you've been screwed over.
Old Jun 7, 2022
  #63
sweethallewis's Avatar
New Member
sweethallewis is an unknown quantity at this point
Thank you for your knowledge I was not aware of this. So when I purchase the sensor I need to get either Mitsubishi or Denso only?
pretty sure that's common knowledge that most OE sensors are denso branded
The problem when people snag sensors at autozone, they don't splurge for the mitsubishi or denso ones, they get the cheap *** duralast-branded sensors that don't play nice, even if they're stamped with the same original sensor manufacturer. Or worse yet, they grab the universal ones that you have to wire in that play even worse. There's a reason why the first thing we ask when people replaced a sensor and have the same issue is, "did you buy it at autozone or did you go Honda OEM?" 90% of the time, the person cheaped out with an autozone sensor.
At the end of the day, it's much easier to suggest to go with a Honda OEM sensor that will knowingly play nice as opposed to rolling the dice on an AutoZone sensor
Old Jun 7, 2022
  #64
New Member
Never mind I found my answer further down in the thread. I will get the Denso.
chrisdao1
Aug 17, 2021 09:49 AM
felixb555
Apr 12, 2017 01:58 PM
califcamper
37
Jun 5, 2014 06:56 PM
seriousdelirium
May 10, 2014 11:44 PM
js999
Sep 27, 2010 02:09 PM
