Runs rough, no acceleration, no code.
Old Jan 21, 2013
clpowell's Avatar
clpowell is an unknown quantity at this point
I have a 2001 Honda civic EX with a 1.7DOHC I am incredibly annoyed at the car. It was running fine and I trailered it for a 600 mile drive. Afterwards it sat in my driveway for about a week. After that it was taken on a drive of about 8 miles and parked. On the return drive it started running terrible. It was stalling frequently and all sense of normal acceleration had left. I have wracked my brain and searched through several forums. I have not found a solution to this problem. The car is throwing no trouble codes. I have already checked to see if the cat was clogged by breaking the connection at the union before the cat. It was not that. If it was cam sensor or crank sensor it should have thrown a code. If it was coil pack it should have thrown a code. The only thing I can think it might be is a clogged fuel filter, but that does not sound too plausible given the circumstances leading up to it. I would be greatly appreciative of any suggestions or advise.
Thanks,
KC
Old Jan 24, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: Runs rough, no acceleration, no code.
Have you checked the TPS(throttle position sensor yet)?
Old Jan 25, 2013
clpowell's Avatar
No. I don't think I have checked the TPS sensor yet.
In the past the only thing that I have seen the TPS do is cause lag in the acceleration due to the computer reading the data indirectly by the o2 sensors.
Please inform me if I am mistaken here.
Thanks
Old Feb 5, 2013
Mylife210's Avatar
Mylife210 is an unknown quantity at this point
I am having the same problem with my 97 civic with a d16y5. I've replaced TPS and fuel filter, no change. You had any luck
Old Feb 19, 2013
clpowell's Avatar
Well I finally broke down and I took the car to a shop. Apparently the car managed to jump time. The shop recommended th have the tensioner replaced and also the idlers pully. While it was open it is also recommended to replace the belt and water pump. Hopefully his helps somebody.
Thanks
KC
Burnout
Jul 15, 2022 10:24 PM
jbradley4809
Apr 7, 2017 04:23 AM
Allecr3
May 22, 2015 01:24 PM
ywgflyer
May 15, 2015 05:05 PM
crowtoo
May 11, 2015 06:50 PM
