Check Engine light help
Old Jun 16, 2011
MrW00t10's Avatar
MrW00t10 is an unknown quantity at this point
the check engine light came on in my 2002 Si, and I had it read today at Advanced Auto Parts. The tech told me he was getting two messages, a camshaft timing problem and then the catalytic converter needed to be replaced. Are either of these a problem? Should I be concerned? I don't exactly have hundreds of dollars to throw at these issues should they be serious. Any feedback is welcomed, I'm still learning my way around my car. Thanks
Old Jun 16, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
Re: Check Engine light help
TDS fails, your car can run rich, will bog down, possibly have acceleration problems, the exhaust will foul your O2 sensors (further causing problems with the car running), then the cat will get fouled (causing it to fail). Eventually, it'll clog up and your car will have reduced mileage and start to run like garbage.
Replace the TDC sensor, then the upstream O2 sensor, then the downstream O2 sensor, then RESET the codes, then if the cat code comes back replace the cat. As it is possible that just the O2 sensors are fouled and the cat might be okay... I'd certainly replace them first and see what happens. (I'd stick with Denso, or maybe Bosch O2 sensors, nobody else.)
Also couldn't hurt to do a tune up after the O2 sensors get replaced too, if you're gonna DIY.
Old Jun 16, 2011
i would say yes they are both serious problems. you will end up spending more $$ later if you wait until something else breaks.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
