2003 civic ex hesistates/sputters
Old Jun 14, 2011
bentley152's Avatar
bentley152 is an unknown quantity at this point
I've read some other posts that seemed to have the similar problem but not quite the same. I have a 2003 civic ex that started sputtering/hesitating/stalling occasionally. It sometimes does it after a cold start and other times after running for a while and re-starting. It doesn't respond when pressing the pedal, then after about 10-20 seconds of sputtering, it decides to go. I've replaced the spark plugs, air filter, PCV valve, and fuel pump relay so far and no luck. No lights or codes showing. I've taken it to a shop and of course it ran fine for them. Any help or advice would be greatly appreciated. Thanks!
Old Jun 14, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
Re: 2003 civic ex hesistates/sputters
Consider the following things that could be causing poor or reduced performance:
- Clogged fuel filter (change it)
- Dirty injectors (run a bottle, maybe even two of Red Line SI-1 through your fuel system to clean it out, you may want to do it after you change the fuel filter so it doesn't loosen up gunk from the filter).
- Dirty Throttle Body (remove it and clean it)
- Dirty IAC (connected to throttle body, remove it from it and clean at the same time)
- Misadjusted/slack throttle cable (check/adjust it, you can do that after putting the TB back on)
- A poorly functioning upstream O2 sensor (replace it)
- Clogged PCV valve (can clean it, or replace it if you want)
- Battery old? Have it tested (AutoZone does for free IIRC, other places may as well).
- Check your alternator belt for proper tension while you're busy looking at things, and inspect its condition (heck, inspect all your belts).
If you do all of the above and still have any issues, some other things...
- Maybe one of your ignition coils is f'd up (direct ignition after all).
- Maybe your timing is off.
- Clogged cat? That can cause hesitation and stalling.
Old Jun 14, 2011
bentley152's Avatar
Thanks, I'll get started with the easiest stuff and go from there. I'll let ya know when I get it figured out!
Old Aug 30, 2011
jackoncruzpr's Avatar
jackoncruzpr is an unknown quantity at this point
Did you ever figure this out? Im having the exact same problems with mine also.
Old Jun 1, 2012
palsana's Avatar
palsana is an unknown quantity at this point
I would so much like to know that as well for my 03 civic ex sedan car.
Old Feb 21, 2025
Man1356's Avatar
Man1356 is an unknown quantity at this point
I had same issue and it was Fuel related. I know this was an old thread but I had already performed some of the basics as listed on your post and finally I had not tried the Red Line S1 and filled up with full tank and one bottle of concentrate and she ran like a champ and no hesitation or cut off. The vehicle had been sitting for a year and we brought her back to life after a number of coolant issues.
Thanks for the great info!
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
deus-ex
Apr 13, 2015 12:29 PM
