2001 Civic Need help with code: "P1361"
Old May 7, 2011
TheHieru's Avatar
TheHieru is an unknown quantity at this point
Exclamation 2001 Civic Need help with code: "P1361"
I have been searching for this problem and end up with no solution.
As many guys out there, I got similar problem: On March 2011, I was on the way to L.A. it was hot and I drove with A.C at around 80mph. Suddenly the CEL ( check engine light) came on, I pulled over and let it sat for an hour then it was fine. It weird. I took it to a local auto shop, it showed the code P1361 ( TDC sensor disconnected), they replaced the new one, it cost me $250.00( good price).
But next month April 2011, It had the same problem, same code P1361.
Any suggestion guys?! I'm hopeless, my car has been at auto shop for a week, because the CEL was gone 1 day after I brought the car there. They cannot do anything without the CEL.
Old May 7, 2011
lazlong's Avatar
Re: 2001 Civic Need help with code: "P1361"
1. Check the wire connections in the back of the sensor connector.
2. Check connections at the ECM/PCM.
3. Check your grounds.
4. Check the harness, especially where it goes thru the firewall.
Old Mar 2, 2021
Snyderman's Avatar
Snyderman is an unknown quantity at this point
That was a long time ago, but I'm dealing with the exact same problem. However... when I replaced the plugs, I found out that someone had used... CRV plugs. I'm guess the wrong sparks might affect the timing, and eventually pop the TDC sensor. Hoping my recent fix, stays fixed.
RefUF
114
Sep 29, 2022 01:10 PM
510racer
Mar 1, 2020 10:00 PM
thesob40
Nov 2, 2008 12:02 PM
hugothepoolman
Oct 2, 2007 09:14 AM
01civi
Jul 22, 2005 12:21 AM
