Intermittent check engine light (CEL)
Old Jan 26, 2010
nighthawk_civic's Avatar
nighthawk_civic is an unknown quantity at this point
Unhappy Intermittent check engine light (CEL)
I have a 2002 Civic LX (102k miles) that had two CEL codes (P0301 -cylinder 1 misfire, P1598 - ELD malfunction) pop up in December 2009.
      Any insight appreciated!
      Old Jan 27, 2010
      Re: Intermittent check engine light (CEL)
      what brand of plug did he use? its very important.
      edit: forgot to mention, ngk and denso are the only brands you should use in a honda. if using different brand, swap them out and i bet its problem solved.
      Old Jan 27, 2010
      RonJ's Avatar
      RonJ will become famous soon enough
      I agree. You could try moving the plugs around as was done for the coil.
      Definitely also try a fuel treatment, such as Seafoam.
      If nothing helps, compression test the cylinders.
      Old Jan 27, 2010
      Checked with the shop. They used a Champion Double Platinum type and agreed that the Honda recommended brands are what you mention, NGK and Nippon Denso.
      Any observations on why the cruise control would be acting up too?
      Thanks
      Old Jan 27, 2010
      RonJ's Avatar
      You may want to test the cruise control off switch on the brake pedal and the actuator.
      Old Jan 27, 2010
      prolly a weak actuator. i had the same issue and rather than replace it, i just tightened the cruise throttle cable. been working fine ever since and it grabs speed within one second of pushing the set button.
      Xuhme
      21
      Aug 7, 2023 03:40 PM
      hernandexz
      Oct 28, 2021 10:52 PM
      tylerginevan
      Apr 27, 2015 12:29 PM
      dooner24
      Apr 14, 2015 07:51 PM
      bahena08
      Apr 11, 2015 05:09 PM
