rev low Around 3000 to 3500.. help
Old Dec 15, 2005
Ricky's Avatar
Ricky is an unknown quantity at this point
Hi i just installed a AEM Cam Gear and A Lighten Flywheel also change oil and Now my car not working normal ... it can only rev 3000 to 3500 around there please help
Old Dec 15, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
is there a CEL (check engine light)? If so, get it read it will help you out. Did you retard/advance timing on the cam gear? Check all sensors are plugged in if any were unplugged.
Old Dec 15, 2005
starstryke's Avatar
starstryke is an unknown quantity at this point
English not work well either?
j/k, listen to someone else.
Old Dec 16, 2005
streetglower's Avatar
Well assuming that you installed everything correctly, reset the ECM.
Old Dec 18, 2005
maybe you installed the cam gear wrong. a lightened flywheel will affect how the car drives, but I'm guessing that since you can't rev past 4k the check engine light came on. Go have it checked.
Old Dec 18, 2005
Ricky's Avatar
cam gear is on 0. All sensors are all plug in. Check engine light is on from removing the catilic convertor.. How do i reset the ECM??
Old Dec 18, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
get the codes read sounds like conflicting issues with the ecu since you dont have a cat.
Old Dec 18, 2005
disconnect the battery or pull the FI ECU fuse. If the cel is on because of no cat, it won't affect performance. a/f is read from the primary 02 sensor
Old Dec 18, 2005
make sure all electrical items are off. start engine and hold it untill 3,000 rpm with no load (park or neutral) untill radiator fan comes on. or engine temp reaches 194 F.
then let it idle for about 5 minutes with throttle fully closed.
Old Dec 18, 2005
Ricky's Avatar
my battery were disconnected when i was working on my car but anyway i will have my valve clearance redo to the middle range tommorow and do what streetglower said..
Old Dec 27, 2005
Ricky's Avatar
still not going not passing 3200
Old Dec 27, 2005
Ricky's Avatar
can it be the flywheel the stock flywheel look like it has a sensor
Old Dec 27, 2005
vtecluder01's Avatar
vtecluder01 is an unknown quantity at this point
if the car starts and runs its not the flywheel, my guess is that you have the cam gear set wrong or the is a conflict with the computer. have the codes read, just because the lights on becuase of the cat being out doesn't mean there isn't more codes. is the car runing rough or skipping?
Old Dec 27, 2005
what did the engine light show? code
Old Jan 4, 2006
Ricky's Avatar
the car runs good but not passing 3500 ..
Old Jan 22, 2006
Ricky's Avatar
errr it's not the flywheel install the stock flywheel and stock camgear and still doing that oh well i guess i going put back the lighten flywheel and the flywheel and have the computer read..i think it might be something wrong with the vtec system.. stay tune..
Old Jan 22, 2006
he is looking into my soul
Old Jan 31, 2006
Ricky's Avatar
waiting for the appointment to the shop any one know why it's not revving high?
Old Jan 31, 2006
well when the engine light turns on, it limits the rpm even if the real problem isn't engine related.
Old Feb 11, 2006
Ricky's Avatar
test
Old Feb 12, 2006
02blkhonda's Avatar
02blkhonda is an unknown quantity at this point
my engine light has been on b4 and my motor did rev all the way to the rev limiter...but his situation it sounds like the vtec might be messed up and the car isnt letting it rev past the engagment rpm...maybe????im not sure but it has to be an electrical problem, at least you know that much
Old Feb 13, 2006
Ricky's Avatar
yah i think the vtec is messed up it's in the shop right hopefully don't cost that much to fix..
Old Feb 13, 2006
02blkhonda's Avatar
****, just bend over and spread your *** cheeks apart so it doesnt hurt so bad.....that **** can get expensive in a shop
Old Feb 13, 2006
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
sounds like the car is running in limp mode, like everyone else said find out what the cel codes are
Old Feb 17, 2006
Ricky's Avatar
tdc sensor not working.. will fix later to lazy= the sensor $65 + the computer testing $132 out of my pocket dang .. hopefully will work ok will i going replace that sensor
Old Feb 18, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
lmaoooooooooooooooooooooooooooooooooooooooooooo i cant stop laffing hahahahaha
Old Feb 24, 2006
Ricky's Avatar
dang after all those work and finally runs good thanks for nothing.. lol
CraigW
Aug 18, 2015 07:06 AM
Doug Lassiter
Aug 9, 2015 09:31 PM
adamdrives
15
Aug 8, 2015 08:53 PM
jessica19699
Jul 30, 2015 01:02 PM
alxz310
Jul 30, 2015 12:18 PM
