check engine light
Old Jun 16, 2004
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
check engine light
I hae a 2002 ex coupe and the engine light has been coming on and going off for the last couple of days. The car is running fine and there doesn't seem to be any fluid leaks or anything else wrong with the car. The dealership wants to charge me 60 bucks just to run the diagnostic. Has anyone else been having this problem? I have 37,000 miles on the car and I'm the only owner. I baby my car(except for the weekends ) and find it hard to believe the the computer would be dead already.
Old Jun 16, 2004
PBCivic's Avatar
PBCivic is an unknown quantity at this point
Check Engine Light
The light comes on when you need to have it serviced (waste of money). If thats not it and its running fine then look in the manual and it tells you how to turn it off.
Old Jun 16, 2004
CivicsRdBest's Avatar
Maybe it's the 30k or 40k mile thing...
Old Jun 16, 2004
robbclark1's Avatar
Retired suspension supermod.
They are talking about the maintenance light. Are you sure it is the check engine light? IF it is, have you gotten gas recently? You may have not put the gas cap on tight enough. To reset, tighten the gas gap and take of the positive cable off the battery for 10 min. Put the cable back on and go about your daily business. If it comes back on, then take it to honda.
Old Jun 16, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
you can just take out the ecu fuse under the hood. that way u wont loose your radio settings.
Old Jun 18, 2004
popNfresh's Avatar
popNfresh is an unknown quantity at this point
hey man hell with the stealership, theres other places where you can get OBDII codes resolved, or try autozone or something, they have OBDII diagnositic sensors which you can buy and keep. I hate the stealership, they're a buncha cumguzzlers
Old Jun 18, 2004
Sgt_BlaZe's Avatar
Sgt_BlaZe is an unknown quantity at this point
If you want to reset it.....
push in your odometer resetter on your dash....
hold it in for a couple seconds...then turn the car to the on position...
wait for all the lights to go out...
turn the car back to off....that should reset it...
Old Jun 18, 2004
Karumba's Avatar
Boredom causes changes ;)
Listen to robbclark, he's a great advice person. Others in this thread do refer to the Maintenance Required light which is in my opinion, but a Check Engine light needs some looking into.
2K2REDCIVIC tells you another way to get around pulling the positive battery cable off, just as long as you are ready to go looking in your fuse box
Old Jun 19, 2004
NoToRiOuSxPiNoY's Avatar
Sekz God
NoToRiOuSxPiNoY is an unknown quantity at this point
Check engine light usually is an indicator that a sensor has failed or sensing something bad. "USUALLY".
Now it could be you're o2 sensor. But 37k is kinda too early for a MIL/CEL to go off. Try RobbClark's way. But if it doesnt work.. you have to take it somewhere that does repair CEL problems.
Old Jul 25, 2004
JayFReaZy's Avatar
which fuse is that?
Old Aug 17, 2004
UltimateWarrior's Avatar
Pimp My Ride!! Please!
UltimateWarrior is an unknown quantity at this point
Check Engine Light on? Well, did you check to see if the engine was still there??
Ok, nevermind... it wasn't that funny. Well, um.. good luck on that! Seriously, you better have that looked at! Don't just reset it man. There might be something wrong and those pesky little lights usually are trying to warn us humans that somethin' aint' right, ya know? (Check Engine I am referring to)
Old Aug 18, 2004
the fuse is in the under hood fuse box on the pass side. without looking @ it i think its the one all the way to the right (the smaller one's), in the middle.
but if u look under the cap it will tell u!!
Old Aug 23, 2004
gotrice's Avatar
gotrice will become famous soon enough
hey im currently having the same problem and cant figure out what it is. it'll come and go but when it comes on my engine feels like it down shifts all the time, i have an auto.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
