left blinker blinking way to fast??
sometimes when i put my left blinker on its gos so fast even the rear left tail light blinks to fast any one know what it is. its ten times faster then the right side blinker. this ahppens sometimes not always though
1. It could be partially grounded. You know where the Injen CAI extension bracket connects? You might wanna tigthen that bolt.
2. One of the bulbs (F or R) on the left side is defective. For instance, if the Front one blows out, then the left will blink super mega fast...
3. Check fuse under your steering wheel. It's a 7.5amp one. I doubt this one though...
I have a injen CAI and when i first installed it. everything in my car was going nuts and somehow i fixed it and I had to take it out last weekend to work on some stuff and when i put it back in it's acting up again and i've tried tightening the bolts and everything else where the ground wires are at but nothings helping... any other ideas?
velocity... if your car is completely stock and you havnt done anything with the electrical system and it continues to blink fast like that... check ALL your bulbs on the left side and then take it into the dealership and have them look at it,... I doubt that its a blown fuse because they would completely stop working if that was the case.
Hey CiViCrAcEr2003, did you get the problem with the lights blinking fixed. I just put in my injen cai and I'm having the same problem. Please let me know what you did to fix this problem, that's if you got the problem fixed. thanks.
I havn't had time to mess around with it yet becuase of work and school but I'm planning on doing it wednsday. I think i'm going to take the bolt that orginally held the ground wires in place and see if it will fit into one of the other holes around the orginal grounding point and just ground everything there. and if that dosent work I'm just going to sodder a wire onto the ground wires and hook it up to the battery so i don't have to keep messing around with everything! I'll let you know if it works or not
alright i figured it out... remove the bolt with the rubber thingie on it that holds down the ground wire and take the ground wire off and put the bolt back on as normal... right below the headlight there is a screw that just holds two pieces of metal together and the nut is permantly attached to the metal (trying to describe it as best as i can cuz my camera dosent work) remove that bolt and put put all the ground wires there and then put the bolt back on and your good to go...
simply put:
1) remove ground wire from factory location
2) remove bolt below headlight and reground everything there.
let me know if you need any help or have any questions.
simply put:
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Touge
Ottawa
Jul 18, 2015 05:39 PM
Touge
Jul 18, 2015 05:35 PM
