Tail Light not working
Old Feb 10, 2025
Christopher0522's Avatar
Christopher0522 is an unknown quantity at this point
Question Tail Light not working
I have a 2001 Honda Civic LX. The passenger side brake light doesn't work. The running/night lights work for both tail lights and they use the same bulb however when I brake the drivers side lights up and the passenger side goes out. I have replaced the bulbs recently and can't figure out what is wrong. I have been doing a lot of research and haven't come to an answer. I saw something like a brake switch that might fix it however before I put more time into random things I would appreciate it if someone could give me some advice on this.
Old Feb 10, 2025
leok99's Avatar
leok99 is an unknown quantity at this point
Re: Tail Light not working
It's a 7443 dual filament bulb so maybe the filament for brake is burn. Move the driver side bulb to passenger side and test, so you know it's the bulb or sth. else.
Old Feb 16, 2025
I switched the bulbs and still the same issue. However, I messed up what I said originally. The driver's side brake light is out. I also checked the brake switch and the wires look attached well. I don't know if it will be a power issue as they light up when dark but when I brake it goes out. So its not the bulb or power from what I know. Any ideas? Its also not the fuse.
Old Feb 17, 2025
Colin42's Avatar
Test for power and ground at the socket and work your way back until you find the short
gosh403
Electrical
Sep 20, 2023 08:12 PM
Jenjen
Feb 25, 2017 02:13 PM
Mattjones
May 22, 2014 02:19 PM
D1n0nly
Feb 28, 2010 05:18 PM
D1n0nly
Feb 28, 2010 05:00 PM
