Replaced Driver's Rear Window Regulator
Old Sep 8, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Just replaced a faulty rear driver's side window regulator with this Dorman unit:
Amazon Amazon
I used this video:
If motor is stuck in the closed in the closed position and you cannot power it down to the access holes for the bolts to the bottom of the window - cut the bare cable on the vertical and the covered cable to the motor. Then carefully lower the window to the access holes at the bottom and remove the last 2 bolts.
For $80, I have a working window again.
Long live the Internet!!
Levibowen95
Apr 1, 2020 04:37 PM
rogerscivic
Exterior
May 25, 2019 06:49 PM
Project Kyra
Mar 5, 2011 10:10 PM
bubbahana
19
Jan 4, 2007 09:15 PM
Biggie Deaf
Exterior
Oct 2, 2006 07:15 PM
