Driver rear window won’t go up or down
Driver rear window won’t go up or down. I replaced the window motor and regulator I also replaced the driver master switch and still nothing. Any ideas on what to check now I was goin to cut old wires and run my own instead of trying to follow the wires all the way back
any advice would help. Thanks
Re: Driver rear window won’t go up or down
Check for wire(s) cracked or broken between the body and door, due to flexing every time the door is opened
If so, I replace the door harness and IMO I thought the price was reasonable last time I actually looked at the price
There could be more wires broken in the front driver's door. Could be the fuse but you need to test
