Passenger side headlight wont turn on.
Just changed the bulb and still nothing. I uninstalled the headlight assembly to polish the plastic and seal it because condensation was fogging it up. The car was outside for a few days and I wrapped the bulbs into a ziploc and ziptied them to keep rain out as the car was sitting outside.
Could water have gotten into the tertinals? Battery wasn't hooked up as I was installing a new clutch and the transmission was out of the car along with the battery. I also sprayed some electrical cleaner into the bulb terminal and then hit it with some air duster and still nothing.
Fuses were fine. I checked the right and left headlight fuses in the fuse box under the hood.
Any help is much appreciated!
Re: Passenger side headlight wont turn on.
Did a read and they were both getting voltage. The problem ended up being a loose negative connector in the plastic plug on the harness. I jammed it back up in its cubby and got a light again.
Thanks for your help!
Never mind. Not out of the woods yet. Now the car battery is dead for some reason. Could I have ****ed something up? I left the plug off of my map sensor today. Could that of created a draw?
torrens21
Jul 29, 2009 10:41 PM
p5hnganthrday
Feb 23, 2007 09:29 AM
ajhdragon
Mar 9, 2005 01:13 PM
