Headlight bulb replacement pass side?
Re: Headlight bulb replacement pass side?
they are both easy. driver side you just pull out the power steering reservoir (it slides out) and get the bulb. the pass side you can reach in no problem without doing anything. if you have really fat hands, you can loosen the battery clamp and move the battery a bit. but this car has the most room ive ever seen to change headlight bulbs. you should try changing bulbs for an rsx. its almost impossible even with baby hands.
thesushiboy
Apr 12, 2015 02:54 AM
