02 honda civic lx dash cluster and gauges not working. And radio and ac controls not lighting up. Any idea what could cause this. Sometimes it all starts working then it goes back out.
Aftermarket deck? Is the orange wire connected?
if it is disconnect it. Did you just buy it?
I just bought car recently. Recent owner told me about the problem. Sometimes everything works normal. But then it will all stop working. What is the orange wire?
Re: Dash gauges and lights not working.
So does it have an aftermarket deck? If it does then you need to disconnect the orange wire that's in the stereo harness. You may need to replace the cluster as well
Previous owner may have pulled it out and put the stock one back in before selling the car. Most likely a problem with the cluster. You'll need one from an 01-03 from the junkyard.
