Driver side power window issue 2005 EX Coupe
Old Mar 20, 2019
icenbikenhike's Avatar
icenbikenhike is an unknown quantity at this point
I recently loss use of my power window on the drivers side of my 2005 Honda Civic ex coupe. The switch does work to operate the passenger side but not the operate the drivers side. I cleaned the original switch with no luck so I replaced it and still no luck. When I do try and use the switch it does dim the lights like it is getting power but not working to raise and lower the window. In the past this would happen intermittently and now it is permanent it seems. Any thoughts before I buy more useless parts. Thanks!
Old Mar 20, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Driver side power window issue 2005 EX Coupe
sounds like the motor is jammed or dead.
you can test it by disconnecting it and jumping the motor direct to a car battery.
polarity doesn't matter, but try switching polarity as well, since one direction is up the other is down.
it should move right away, if not replace motor.
Old Mar 20, 2019
Ok that is simple enough and it looks like the motor is not too expensive if it does need replaced. To youtube I go for some direction. Thanks!
Old Mar 21, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Check the fuse. On a sedan, it is the #23 (20A) in the Under-Dash Fuse/Relay Box. Might be same for coupe.
Old Mar 21, 2019
Ok I will try that first this weekend when I dive into this project. thank you
Old May 20, 2020
Robert Bowring's Avatar
Robert Bowring is an unknown quantity at this point
Did you sort out the window problem as I am having the same isue thanks
Old May 20, 2020
I ended replacing the entire motor. I have an extra drivers side switch if you want to purchase it hit me up. It took maybe 1-2 hours to replace.
Old May 30, 2020
Sorry I have 2 switch units and 2 window winder/regulators. I am still having problems. I will have another look when my health improves. Thanks anyway for the offer.
Majestichun
Aug 2, 2018 06:52 AM
ImSoFreaknWhite
Nov 16, 2013 01:09 PM
EEES
Dec 9, 2012 11:54 AM
ndccpf1
Jul 5, 2012 09:45 AM
SmSLegend
Feb 16, 2012 07:44 AM
