2002 EPS light
Old Jan 8, 2019
Richardjsandfor's Avatar
Richardjsandfor is an unknown quantity at this point
2002 EPS light
Hi,
i have a 2002 Civic that has the electrically assisted steering without any fluid.
i seem to be having a very intermittent issue when driving, the EPS light comes on and the steering immediately tightens up. The fault doesn’t happen every time - it might not happen for says... then I’ll be reversing slowly and it’ll start coming on.. turning the engine off and on usually clears the problem.
I’ve taken it for a battery test, which has performed fine, I’m looking for some other tests I can do, before I have to take it to Honda for an expensive diagnostic.
i have noticed that when I use the electric windows, the air conditioning will reduce in power fairly significantly.
has anyone experienced a fault like this and how can I beat work out what the issue is?
Old Jan 8, 2019
Slumpertcivic's Avatar
Re: 2002 EPS light
There is a position sensor on both the output to the wheels and the steering wheel itself. If the computer “detects” a abnormal reading it shuts down the motor as a safety measure and turns the light on.
I would start by buying one those nifty power outlet USB adapters that also shows car voltages. Might be as simple as a failing alternator.
Old Jan 8, 2019
Colin42's Avatar
Re: 2002 EPS light
my guess would be to check the alternator as well
Old Jun 11, 2023
Adzlin's Avatar
Adzlin is an unknown quantity at this point
Re: 2002 EPS light
Originally Posted by Richardjsandfor
Hi,
did this ever get solved ?
Old Jun 12, 2023
BrotatoChip's Avatar
Super Moderator
Re: 2002 EPS light
Check EPS fault codes.
Old Jun 13, 2023
Adzlin's Avatar
Re: 2002 EPS light
I don't have any fault codes when the EPS light comes on. Every scan I do says nothings wrong
Old Jun 14, 2023
Colin42's Avatar
Re: 2002 EPS light
Does your scanner do more than just engine codes?
Old Jun 14, 2023
Adzlin's Avatar
Re: 2002 EPS light
I'm guessing not. It's just a cheap one
Old Jun 14, 2023
Colin42's Avatar
Re: 2002 EPS light
I have bluedriver, it does basically everything
Old Jun 16, 2023
Super Moderator
Re: 2002 EPS light
Most cheap scanners will only do powertrain faults.
I went to Autozone once to have them read an ABS fault and theirs would only read powertrain faults too. What a joke. I hate parts stores. Bought myself a better scanner soon after.
HiImBrandon
Jun 1, 2015 07:34 AM
Sea Bass
Feb 13, 2015 09:16 AM
civ01
Feb 3, 2013 11:07 AM
babzog
Buy, Sell, & Trade - Archive
Aug 6, 2010 09:53 PM
cranker
Jul 16, 2005 01:19 PM
