Can't line up alternator bolt...help?
Old Mar 29, 2015
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Upper (pivot) bolt in no problem. The lower alternator hole won't line up with the arm that holds the locknut. The alternator won't line up throughout the range of motion, from the top of the bracket to the bottom. What did I screw up? Name:  72gdMyD.jpg
Old Mar 29, 2015
Re: Can't line up alternator bolt...help?
Loosen the OTHER bolt holding that bracket.
Old Mar 29, 2015
I'll just show myself out.
Old Jun 20, 2019
MW650's Avatar
MW650 is an unknown quantity at this point
This is my 1st time ever using a site like this so sorry if I'm doing this wrong. I realize this is 4 years old but I am having the same issue. I replaced my head gasket and got everything put back together (including the alternator) and realized I hadn't set my timing. So I took everything back apart to set the timing and now getting the alternator back on looks like the picture above. If I loosen every single bolt holding the motor mount and alternator to the block then I can manage it however, I cant access the bolts under the alternator to the mount.
Old Jun 21, 2019
remove alternator again, loosen the bolt of the bracket
Old Jun 21, 2019
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
There is a 14MM bolt on the slotted bracket holding it down that you need to loosen. No need to take it out, just loosen it enough that the bracket moves up and down freely. This will give you enough movement in the bracket to line it up and get the bolt in the alternator. Let us know if you need more help
Old Jun 21, 2019
BrotatoChip's Avatar
Super Moderator
Ensure you tighten that bolt back up afterwards or you may be replacing the ECU sooner than you'd like.
Old Jun 21, 2019
You are right! Electricity takes the path of least resistance. If the alternator doesn't have a good ground to the engine, the path of least resistance becomes the control wiring. The ECU wouldn't appreciate being forced to eat the entire output of the alternator.
Old Oct 25, 2021
ExplorerXLT's Avatar
ExplorerXLT is an unknown quantity at this point
Thank you thank you thank you! Just spent 2 hours arguing with this same problem!
Daniel Fenn
Electrical
Apr 7, 2018 01:55 AM
vtville
Jun 20, 2011 11:33 PM
creaker2
Oct 17, 2010 05:07 PM
richs1000
Dec 16, 2009 02:03 PM
vtville
Apr 13, 2009 04:48 PM
