How to move washer fluid reservoir for low beam bulb change?
Old Aug 21, 2012
JeanLucPicard's Avatar
JeanLucPicard is an unknown quantity at this point
Hey gents,
Been using the articles on this site for a while, but finally couldnt find something by searching.
Want to replace my headlights, the low beam on the driver side is giving me a hard time. I changed the high beams simply enough, but I don't know how to get around the windshield fluid reservoir to loosen the screws on the low beam.
Any tips?
Old Aug 21, 2012
Re: How to move washer fluid reservoir for low beam bulb change?
not really sure what youre asking, but the washer fluid reservoir is one piece and must be removed by taking off the bumper. same goes for removing the headlamp housings. to remove the bulb, you just lift up the PS fluid reservoir. nothing extra needs to be done and our headlight bulbs are very easy to change.
Old Aug 21, 2012
scooty's Avatar
scooty is on a distinguished road
Are you trying to remove the little circle light that turns on with the first twist of the head light switch?
You don't need to remove the washer reservoir. You can access it from inside the wheel well. Just peel back the fender liner a little bit. There is a diagram in the owner's manual.
Old Aug 22, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Yea, you shouldnt need to remove the washer fluid resevoir to do it...its a tight squeeze, but the bulb is replaceable...and if you really think you have to do it another way, it will be easier to remove the whole headlight, rather than the resevoir, as the bumper will have to come off for both.
Old Sep 6, 2012
**** my life...so I finally changed the bulb
but I dropped a small screwdriver....and it didnt come out the bottom, and no matter where I look, I can't find it.
CAA expired 2 weeks ago apparently and I didnt renew. So this screwdriver drop is probably going to cost me $100 for the tow, plus another hundred at Canadian Tire
And Im missing work to do this, so thats another $100
Old Sep 6, 2012
happened to me and i found the screwdriver years later doing some unrelated work. luckily it never fell out, and i really dont even remember losing it.
Old May 20, 2023
Wmac's Avatar
Wmac is an unknown quantity at this point
Originally Posted by JeanLucPicard
Hey gents,
Dealing with same issue!! 2005 must be only year they designed location for front drivers side headlamp to be inaccessible
Old May 20, 2023
TokyoCornflower's Avatar
TokyoCornflower is an unknown quantity at this point
You dropped it by the headlight? If you want to find it I would loosen the splash guard and fish around you might find it, or pull the bumper cover, a lot of plastic clips but actually very easy to get off (at least on a 2002), once I figured that out I have had mine off many times for pretty small reasons. Good luck, I wouldn't worry about the screwdriver until you have time for it, but that's just me and the level of luck I have found in life.
Old May 21, 2023
Colin42's Avatar
That was 11 years ago...
i didn't have any issues with the driver's side on my 05, had to loosen the battery hold down for the passenger side
Twistedballs
Exterior
Oct 22, 2019 12:59 PM
pcds146
Jun 11, 2010 11:33 PM
Donna
Oct 23, 2007 01:52 PM
gearbox
Nov 22, 2004 07:56 PM
HippyCivicEX012
Jul 8, 2002 11:16 PM
