Headlight right side low/hi not working on 04
Old Nov 17, 2011
edgenet's Avatar
edgenet should not be trustededgenet should not be trusted
Hi
The headlights on the right side hi and low beam work intermittingly. On rainy days they do not work at all. Looks like a corroded wire i did find a wiring diagram for a 01 to 03 is the 04 different?? If so can someone point me to a 04 diagram? Thanks<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Nov 17, 2011
CraigW's Avatar
Re: Headlight right side low/hi not working on 04
01-03 = single bulb per side
04-05 = 2 bulbs per side
Can't find 04-05... will attach it later, check back.
Old Nov 18, 2011
edgenet's Avatar
I removed the battery checked the bulb wiring all look good. I also removed the fuse box looked under where the wires terminate all look good, wierd all the plugs are packed with grease. I have never had an electrical problem in a GM car this is my 1st Civic had it since new also replaced the alternator last summer. I would hate to take it to the dealer if they have to trace the wiring it could take hours and hours. I will also try to find a diagram. Thanks
Old Nov 18, 2011
edgenet's Avatar
I googled the right side lights of on 04 Civic and it seems a common problem. I am wondering if the circuit in the turn signal is defective. Anyone remove the streering wheel covers to get at the turn signal?
Old Nov 19, 2011
edgenet's Avatar
I forgot to mention that I have a DRL (day time running light) flash every now and then on the dash and apperantly this will effect the head lights. This module is around $200 I found a fix on you tube
http://www.youtube.com/watch?v=PmsAt...eature=related
Old Nov 19, 2011
CraigW's Avatar
The low beams ground direct and are not associated with drl.
Here is the schematic, If you need further info let me know.
I can provide the theory section but the schematic explains a lot.
Sorry it took so long to attach.
File Type: pdf
Old Nov 19, 2011
edgenet's Avatar
CraigW
Thank-you for the diagram I will pull out the DRL module 1st and check the soldering points as stated in the youtube and go from there. Thanks
Old Nov 19, 2011
CraigW's Avatar
Do you loose both high and low at the same time ?? or 1 or the other independent ??
Old Nov 19, 2011
edgenet's Avatar
90% of the time the right lights do not work (Hi/Lo) and at times the hi beam will only work and other times the low beam will not work and the DRL lights will not work on both sides at times. So I thought I would fix the DRL 1st and go from there.
Old Nov 20, 2011
edgenet's Avatar
Ok I removed the DRL module (very easy in an 2004) I looked at the soldering points related to the 2 relays they all looked good I took the youtube advice and re-soldered all the points. I re-installed the module and everything works. If anything changes I will update. Just saved around $400 to $500 if I had taken the civic to the dealer.
Old Nov 20, 2011
CraigW's Avatar
Good fix.
Old Jul 28, 2018
abdiel4's Avatar
abdiel4 is an unknown quantity at this point
Originally Posted by edgenet
Hi
<o></o>
Can you provide the website that shows the diagram for the 01-03 pls................. thank you
DaDude
Apr 11, 2008 06:27 AM
rev125yz
Feb 20, 2008 10:56 PM
loosha808
Nov 21, 2006 03:42 AM
herroherror
Lighting
Jun 21, 2006 12:08 PM
Batman Civic
Dec 24, 2004 01:46 AM
