04 Headlight Problem
Old Nov 21, 2006
loosha808's Avatar
loosha808 is an unknown quantity at this point
Ok here's the problem I've been having. I just recently installed a set of Luminics bulbs in my low beams and every now and then only my driver's side bulbs have been giving me troubles. My driver's side low beam sometimes doesn't turn on or it will flicker and eventually turn on. Also when it doesn't turn on, I try to turn on my high beams but even that bulb doesn't work. The high beams only turn on when my low beams are working. Anybody know what could be causing this? I don't think it's my bulbs or fuses because it wouldn't work period if it was. Could it be a connection? If my low beam connection was bad, wouldn't the high beam still work? Any help please..
Old Nov 21, 2006
rev125yz's Avatar
rev125yz is an unknown quantity at this point
are your headlights aftermarket? mine would do that to, but i think it was just a loose connection because i could press the wires tightly together, and they would stay on. i did this periodically for a while and now they just stay on
Old Nov 21, 2006
loosha808's Avatar
no, mine are the oem headlights. i just blacked them out though.
Old Nov 21, 2006
rev125yz's Avatar
well then if they flicker when u move the wires, check ur connections then electrical tape them
stryder12
Jun 30, 2015 08:33 PM
carid
Jun 5, 2015 11:51 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
