A cracked cowl
Old Feb 26, 2022
civtorc's Avatar
civtorc is an unknown quantity at this point
A cracked cowl
Hi,
I cracked the cowl panel at the base of the windshield of my 2017 Civic while clearing ice from it; there is a gaping hole (probably 3-4 inches long, almost an inch wide) in it. Two questions:
1. Do I need to worry about any pieces that fell into the hole?
2. If I cover the hole with duct tape until I can replace the cowl, will that do any harm? The cowl had holes in it, which I assume play some ventilation role, but I really don't know anything about this.
Thank you.
Old Feb 27, 2022
Colin42's Avatar
Re: A cracked cowl
Pictures?
yes and yes, if something had holes and you block those holes, you're going to cause problems. The chunks that fell in are going to be bouncing around and make noise. Once you have it off you should be able to find all the bits.
You can get one from a junkyard cheap
Old Feb 27, 2022
civtorc's Avatar
Re: A cracked cowl
Originally Posted by Colin42
Pictures?
Thank you very much. Common sense advice is often best...
SlowboyZ
Nov 27, 2017 04:42 PM
torontob
Jun 8, 2011 10:40 AM
RHCP0801
Mar 3, 2006 06:23 PM
phlipsidez
Dec 20, 2002 08:34 PM
civic2k2
Jun 2, 2002 08:42 PM
