Electrical Post your Electrical issues here!
Charging System problem Error [solved -rodents and wiring don't mix up, again]
Old Jan 5, 2022
markrstephen's Avatar
markrstephen is an unknown quantity at this point
My 2016 has been displaying this error for a couple of weeks now.
The car runs fine. Battery is 2 months old and checks out fine as does the alternator. I ran my OBD scanner and there are no codes. I checked the fuse box and nothing obvious.
Any ideas what this means or how to solve or just clear it?
Old Jan 5, 2022
BrotatoChip's Avatar
Super Moderator
re: Charging System problem Error [solved -rodents and wiring don't mix up, again]
Have you checked the battery voltage? Specifically while the engine is running?
Old Jan 5, 2022
Colin42's Avatar
How do the battery connections look?
Old Jan 5, 2022
Yes, all is good with the battery and connections.
Old Jan 5, 2022
Colin42's Avatar
What's your voltage with the car running?
Old Jan 6, 2022
I had it checked at a local shop they said it was fine, but I'll have it checked again. The battery is only 2 months old.
Old Jan 6, 2022
I just checked again. Car has been sitting out all night, battery tested at 12.47V and when turned on at 14.3V.
So does this mean the battery is not holding a full charge? it's around 48 degrees F here.
Old Jan 6, 2022
Colin42's Avatar
Those are normal numbers for car off, and then 14.whatever engine running
Old Jan 7, 2022
Thanks.
This one is puzzling as to what the issue is. Car drives perfectly normal.
Old Jan 7, 2022
honestly, if the voltage looks correct, i would take to honda dealer
Old Jan 7, 2022
Thanks, I was hoping to avoid that, but seems like the best option.
Old Jan 10, 2022
I noticed this over the weekend. Near the battery is a wire that looks like it was cut. Anyone know what this wire is for or where it should be reconnected?
Old Jan 10, 2022
To add to this, I found a rat nest under the hood of one our cars, so maybe one crawled into the hood and chewed this wire.
Old Jan 10, 2022
ah, the famous rodent chew...
Old Jan 10, 2022
Super Moderator
That would absolutely do it. That's for the battery sensor, load detector I believe.
Old Jan 11, 2022
Re: Charging System problem Error
I found this image online, that's it with the red circles. I just don't see the other part of the wire anywhere, not sure what to reconnect to. A friend of mine has a similar year Civic I am going to take a look under the hood and see if I can match it.
Old Jan 11, 2022
Super Moderator
I'm not sure if it's a connector or what but it goes to that plastic piece underneath where the negative cable goes to the battery.
Old Jan 21, 2022
Thanks everyone for the help, problem fixed. I just had to splice the wires back together.
Now I just need to deal with the rat problem.
Old Jan 21, 2022
Call Tom to make up with Mickey
Nephlite2k
Electrical
30
Apr 26, 2021 05:33 PM
01HonderCivic
May 9, 2006 12:40 PM
Nemo
Jan 6, 2005 09:30 AM
