P2583-87 Lost communication with the Millimeter Wave Radar
Hi,
daughter hit a fox. Errors now on dash for Collision Mitigation, ACC issue, Millimeter Wave
Code reader says P2583-87. "Lost communication with Millimeter Wave Radar"
Only troubleshooting guide I found for P2583-87 relates to Honda Pilot. Went through the guide, checked fuses under dash (slot 4 and slot 24 - 5 amp fuses), checked voltage across Millimeter harness pin (terminal 5) and ground , both OK. Then the Ground continuity check on harness (terminal 1 to ground) did not work. Not sure what to do next.
Wave Radar unit is secure and clean as well as the cover--no visible damage.
Any ideas please? Thanks
Re: P2583-87 Lost communication with the Millimeter Wave Radar
It's a diy if you're posting how to fix it.
does it need to be recalibrated maybe? Or the unit may be damaged internally, not sure how sensitive they are
diy section is for people showing how they did the job, not for people asking how to do.
You have an issue, it goes to issues section.
JetsterDajet
Aug 16, 2015 01:56 PM
LorenzoC0395
Mar 31, 2015 11:20 PM
DeX
28
Jul 25, 2011 01:51 AM
