Electronics Post your questions about Electronics problems here!
Auto Window Question
Old Aug 7, 2019
tmacski's Avatar
tmacski is an unknown quantity at this point
Hi Everyone, Q: 2010 Civic coupe, is there any way to make the pass. side window auto up/down like the drivers window?
Old Aug 8, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Auto Window Question
Probably.
I imagine you could run a duplicate set of wires from the drivers master switch, to the passenger.
-make sure to run them in parallel and fused.
There may be issues though if the auto roll is position based and not range based.
Meaning if there is a stop sensor at the top of the window that cuts power then having the two windows at different heights will cause issues.
How ever, if they simply roll up until they max out then you'll be fine. You may have to pull the switch twice though, if for example, the two windows are at different heights when activated.
oragex
Mar 8, 2017 01:14 PM
craddmd
Aug 12, 2011 11:37 PM
slickstarnz
Feb 9, 2007 02:03 PM
Whelan
Dec 23, 2004 02:21 PM
Whelan
33
Mar 4, 2004 07:00 PM
