Brakes Post your questions about Brakes problems here!
Caution lights
Old Dec 16, 2020
mhumphries77's Avatar
mhumphries77 is an unknown quantity at this point
Caution lights
Park system problem
Park hold system problem
Power steering system problem
Vehicle stability assist problem
Hill start assist problem
All these lights came on the same time, anyone have any suggestions?
Old Dec 16, 2020
Re: Caution lights
Check electrical connections (really, battery terminals) and drive around for a bit. Alternatively, disconnect the negative battery terminal for a bit, make sure it's on adequately when you reconnect negative terminal, then drive around for a bit. I'd be surprised if every single one of those components actually experienced an issue simultaneously.
Old Dec 16, 2020
Re: Caution lights
low voltage usually causes mayhem to electronic components and lit a Christmas tree on the dashboard.
Old Dec 16, 2020
Re: Caution lights
case in point, my 2018 did it to me twice. Once shortly after getting my car, and once after installing my HID relay harness. I just double checked battery terminals the first time, and I messed up and didn't tighten something down enough the second time. Zero actual issues, and no christmas lights on my dash since.
Twinzam2785
Aug 16, 2005 08:59 PM
01civi
Jul 17, 2005 12:08 AM
01SedanLX
Jan 2, 2004 06:32 PM
Mex
Apr 22, 2003 06:40 PM
