General Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
2021 civic Sport All errors being displayed (Solved)
Old Jun 13, 2021
bobt1962's Avatar
bobt1962 is an unknown quantity at this point
We just picked up a 2021 Civic and after driving about 20 miles all the error warning started popping up from bad braking system to low tire it just displays one after another.
Tried to do the battery disconnect and that did not work still happening.
Old Jun 13, 2021
Re: 2021 civic Sport All errors being displayed
2021 still in warranty. Take back to dealer.
low voltage wreaks havoc in the electronics and light a Christmas tree in the dash
Old Jun 13, 2021
After you disconnected the battery, did you make sure connections were good and drive around for a bit afterward?
Old Jun 14, 2021
bobt1962's Avatar
Yes after disconnecting we did drive still happening. I know it’s still under warranty and the dealer will address the issue but I wanted to know why this could happen. As mentioned low voltage is a possibility. It’s at the dealer now and at first check they said “never saw this before”. That does not give me a warm and fuzzy feeling. I will update this thread as soon as I get more info maybe it can help someone else 🙂
Old Jun 14, 2021
I've had the random Christmas tree thing go on before in my 18 hatch. Disconnected the negative terminal for a minute, then tightened electrical connections (pretty much just the battery terminals) and everything went away. Sucks that Honda dealerships charge a $150 diag fee (at least that's the fee here in Vegas), but if quick fixes like that don't work, might warrant a trip. Figured I'd do the dummy checks, just in case. Can't assume anything without being there physically
Old Jun 28, 2021
bobt1962's Avatar
This issue has been resolved.... Turned out that a defective speed sensor was the cause of the issue.
Hondaforeman
General 10th Gen
Feb 2, 2021 10:54 AM
Leanne
Jun 20, 2020 06:01 PM
