Check Engine Light Came on
Old Apr 29, 2003
TTCIVIC's Avatar
TTCIVIC is an unknown quantity at this point
Unhappy Check Engine Light Came on
My check engine light came on... Anybody ever had the same problem. If yes, what had caused it to come on. I thing it might be the cat since I hear strange noises everytime the road is wet. And since my car is slammed so much, i always hit the damn thing going over speed bumps. I'm going to the dealer on thursday, i'm afraid they might not cover it with the warantee.... Any advice guys?
Old Apr 29, 2003
BIG's Avatar
BIG
time for an oil change?
Old Apr 29, 2003
TTCIVIC's Avatar
it's not the maintenance light.... it's the enigne light
Old Apr 29, 2003
nitehawk's Avatar
If your problem is directly related to something you have modified on your car you will have a hard time getting it covered under warranty.
Good luck though and hopefully its nothing too expensive.
I do have a complete stock exhaust system in my garage. I took it off my car with only 1000kms on it when I put my Magnaflow Cat back on.
If you need to buy one let me know and maybe I can sell it to you instead of the dealership raping you for one.
Old Apr 29, 2003
BIG's Avatar
BIG
good call nitehawk, you'll save him a TON of cash
Old Apr 29, 2003
TTCIVIC's Avatar
thanks for the info....
i've changed the whole exhaust system from the cat back with 21/4 piping and magnaflow resonator. So if there is a problem with the cat, i'm thinking of getting a high flow cat. I'm going into the dealer on thursday, i'll see what happen... I mean the car drives perfectly now, nothing's wrong with it... it's just the light
Old Apr 29, 2003
GuSTo's Avatar
GuSTo is an unknown quantity at this point
its probably your o2 sensor....might have got knocked loose from scraping or something.....
Old Apr 29, 2003
BJAI's Avatar
BJAI is an unknown quantity at this point
ya....i think it's probably the sensor.....
Old Apr 29, 2003
TTCIVIC's Avatar
i hope so.... if that's the case, it's easy to fix
Old Apr 29, 2003
BJAI's Avatar
yo terrance...so what up wif your car...?
Old Apr 29, 2003
oldskool's Avatar
oldskool is an unknown quantity at this point
how many klicks are on your car?
Old Apr 30, 2003
1llmatic's Avatar
1llmatic will become famous soon enough
when the check engine light came on in my car it was because of the catalytic converter...its covered under warranty for 100 000km.
Old Apr 30, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
but since he changed to aftermarket muffler and pipe and resonator
the service advisor(s) might be a **** and say "your car is modified and the exhaust warranty will be void....blah blah blah" and they might not fix the cat under warranty
hope everything works for Terence
good luck man and call me up soemtime to chill
Old Apr 30, 2003
BJAI's Avatar
for sure they will not warrantee any mods you did on your car...
they will not warrantee....i had my tranny broke down a few time...
they can't not warrantee me...because i didn't do anything to the tranny..... in your case...you did a new exhaust system.... factory will not warrantee...
Old Apr 30, 2003
Dartheo's Avatar
SLIPSTREAM R
Dartheo is an unknown quantity at this point
Re: Check Engine Light Came on
yah... mine does that also... it makes a loud ticking noise... anyone know wut is causing it???
Old Apr 30, 2003
BJAI's Avatar
could be your mid pipe hitting..... i had that happen to mine too..
but i re arrange mine...and it's gone.....
Old Apr 30, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
Probably just the sensor. Good luck with this one Terrence!
Old Apr 30, 2003
BoSS's Avatar
BoSS is an unknown quantity at this point
I know this one guy that had his car slammed and he hit a large bump on the highway and bottomed out with the header smacking the ground....It gave the header a hairline crack but mad a lot of bad noise....check it out
Old Apr 30, 2003
Bluelle's Avatar
Bluelle is an unknown quantity at this point
check it out quick time....
Old May 1, 2003
TTCIVIC's Avatar
the light actually went off.... so i dun know if i should still bring it back to the dealer or not?
Old May 1, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
Nah, it should be fine, you should have resetted the ECU (remove ECU fuse for like 10seconds) and see if it comes back on.
Old May 1, 2003
TTCIVIC's Avatar
i didn't go to the dealer... i couldn't wake up .. haha
Old May 1, 2003
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
It could be your catalatyic converter... i had to replace mine, and the check engine light went out.
My previous problem was the tranny....
Your light WILL COME BACK ON. Wait until its back on, and head straight for the dealership. I bet it's your catalatyic converter.
Old May 1, 2003
iamfob's Avatar
01Coupe your is a LX right? so the cat is below the header right?
TTcivic is Si so his cat is somewhere below the front seats under the car of course
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
