Should I get a buffer for waxing?
Old Mar 25, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
Is it worth it? Would it damage the coat if used improperly? Are there any brands/models that are especially good?
Old Mar 25, 2003
sg2kca's Avatar
sg2kca is an unknown quantity at this point
ask civicdude, he's like a pro at detailing. I also read orbital buffers suck
Old Mar 25, 2003
R1Style's Avatar
I don't think you should get one unless you kinda know what you're doing. You could definatly ruin the clear coat/paint on your car if used improperly.
I suggest you just do it by hand and save some money. It's a little more time consuming, and a bit of a work out but really, you probably won't use it enough to get your money's worth.
Old Mar 25, 2003
DragonAce's Avatar
DragonAce is an unknown quantity at this point
buffers are only good for applying..just don't leave it in any spots for very long, you'll burn thru the clear-coat..
for polishing off def. use the hand method..
front to rear on all horizontal surfaces and up/down on the verticals..
Old Mar 27, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
I got one of those canadian tire ones and it's ok. It's really up to you, even if you get just remember you still have to manually buff certain areas by hand.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
01SOHCcivic
Apr 16, 2002 08:20 PM
01SOHCcivic
Detailing
Apr 16, 2002 09:26 AM
AndyPandy
Detailing
Mar 16, 2002 02:54 PM
insan
Detailing
Jan 29, 2002 09:41 AM
