Fiberglass sides and rear?
Old Jan 17, 2003
nitehawk's Avatar
I was just wondering if anyone knows or has had any problems with fiberglass side and rear skirts. There is a company that copys the Wings West G5 kit but I think they are made out of fiberglass.
Would I have to worry about them breaking or cracking even if they are sides and rear only. I could see being worried about the front if I was to bottom out or something, or should I just avoid fiberglass completely.
Any info would be appreciated.
Thanks
Old Jan 17, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
fibreglass = crack
Imagine if someone parks and slightly hits your rear bumper (which happens, sometimes you don't even know it) and the fibreglass cracks?
Imagine going over a speed bump and scrape hard enough....
Old Jan 17, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
I have fibreglass sides and rear and they haven't hassled me yet. Except the time when I got my car back from the shop after the paintjob and 2 weeks later a cube van scratched the bumper but that's it...
Old Jan 17, 2003
Booohahaha's Avatar
BAD MON
no they would not crack unless u hit something hard on them
unless u keep taking them on and off they will change shape.
but if its a one in a life time thing and u wont take them off then its good to go
it will be cheaper to get urathane front and fiberglass everything
Old Jan 17, 2003
Unstoppable's Avatar
Unstoppable is an unknown quantity at this point
Fiberglass is fine....as long as its "hand laid" and not those cheap replicas that use a gun
The reason why Fiberglass has such a bad rep is because of all those cheap replicas so people think All fiberglass is bad and cracks
In fact, most Japanese fiberglass kits are hand laid and can be as durable as Polyurethane. Forgot to mention, once Polyurethane cracks, its not repairable, where as Fiberglass can be fixed. Another thing you should note is that Polyurethane warps in shape if exposed to hot temperatures, where as Fiberglass won't. Normally, fiberglass are used for more extreme looking kits as it is more flexible to work with than PolyUrethane.
Old Jan 18, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
anyone know if there are fibreglass side skirts for kiminari or xenon or any aftermarket sides?for 2k1civic coupe
Old Jan 19, 2003
Liro's Avatar
Back from the dead
how do you know its hand laid for with a gun? is there a way to tell by looking at it or something? i dont really trust too many people to tell the truth about something like this....
Old Jan 20, 2003
Quote
[hr]Originally posted by: Liro
how do you know its hand laid for with a gun? is there a way to tell by looking at it or something? i dont really trust too many people to tell the truth about something like this....[hr]
Fiberglass:
Chopper Gun- Chopper gun fiberglass is heavier, weaker, uneven, brittle, and can be very wavy. The only advantage of chopper gun fiberglass is the cost, and speed of the maufacturing. It is almost impossible to find a chopper gun fiberglass component that fits well. The first thing to do is look for waves on the finished side. If there are waves in the finish, it's chopper gun. On the underside you can see pieces of fiberglass throughout. It will look like it was shot out of a gun. and alot of the times you can still see raw pieces of fiberglass sticking out like hairs.
Hand Laid- Hand laid fiberglass will be lighter yet sturdy. Never brittle. If you look from the side of the component, you should be able to see the layers of cloth.
Urethane- When it comes to urethane there is high pressure and low pressure urethane. In short, high pressure is lighter, stronger, and will withstand a much higher temperature than the low pressure urethane. High pressure urethane costs more to produce parts, thus the price difference. Remember, urethane will change shape at a given temperature. The question is, at what temperature will it start sagging, distorting, and falling apart?
Hope that helps, it should help you in deciding what kind of kits to get.
Old Jan 21, 2003
Sunapollo's Avatar
Sunapollo is an unknown quantity at this point
This is very helpful stoppable thanks !!
Old Jan 21, 2003
nitehawk's Avatar
Quote
[hr]Originally posted by: Sunapollo
This is very helpful stoppable thanks !! [hr]
Yes thanks for replying guys. Can always count on CanEast for advice and info
Old Jan 22, 2003
Liro's Avatar
Back from the dead
Quote
[hr]Originally posted by: Unstoppable
Quote
Fiberglass:
Hope that helps, it should help you in deciding what kind of kits to get.[hr]
great info. thanks!
KronikScott
Jun 9, 2015 08:00 PM
leon1
Apr 28, 2015 07:32 PM
ej8
Apr 13, 2015 06:36 PM
dablueXcivic
Dec 3, 2001 11:34 AM
