OT: clearing headlights.
Old Dec 22, 2002
Chigga's Avatar
Chigga is an unknown quantity at this point
there has to be an easier way???
im doing mine on boxing day...... u dont have to take off the front bumper do you??? thats OBSERD!
if u think about it, how are u going to change your turn signal bulbs....... if they burn out???
TAKE THE FRONT BUMPER OFF???? B.S
im sure all i have to do is jack my car up and loosen the headlight assembly out can i not????
someone help me out who has done this......
thanks!
Old Dec 22, 2002
watewate's Avatar
watewate is an unknown quantity at this point
turn signal bulbs, you just remove inner plastic fender piece, and out comes the old signal bulb and in goes the new one. so no bumper removing there.
Old Dec 22, 2002
Chigga's Avatar
yeah but if i do that can i still remove the whole headlight unit????
Old Dec 22, 2002
watewate's Avatar
removing headlight assembly = remove bumper
removing any bulbs from the headlight = bumper stays on.
Old Dec 22, 2002
Chigga's Avatar
im guessing u have done it>????
got any pics?
thanks for the advice!
Old Dec 22, 2002
newkid's Avatar
newkid is an unknown quantity at this point
if u can remove ur headlight assembly without removing the bumper u can probably take off ur underwear without taking off ur pants...
good luck trying...when i did my light i had to take the bumper off...
and if u check ur manual theres instructions on how to change ur turn signal bulbs without taking off the bumper
Old Dec 23, 2002
Liro's Avatar
Back from the dead
impossible not to take the bumper off if you're going to remove the headlight assembly, there are two bolts that attach to the mounting bracket that attach the headlight to the car. you cannot, absolutely cannot get to these bolts without taking off the bumper. bumper removal is simple. post your concerns and we will walk you through it...lots of experience on this board on this diy.
Old Dec 23, 2002
jer2k's Avatar
jer2k is an unknown quantity at this point
It may be possible that you dont have to take the entire bumber right off the car...
Check out this Thread
Looks like you just have to tilt it forward, or something.
Old Dec 23, 2002
chanpakto's Avatar
chanpakto is an unknown quantity at this point
Yeah, you don't have to physically remove the bumper. You can leave the pegs on the buttom in. You have to take the top part of the bumper off. Once you can get access to the nuts for the headlights, it is good enough. I had my bumper hanging when I did mine.
Old Dec 23, 2002
Chigga's Avatar
thanks for the input guys..
its no big deal, it just when i do something and when it doesnt workout..... id probably torch my car.....
hahaha... thats how impatient i can be... and i lose bolts too.... argggggg...
Old Dec 23, 2002
OyD's Avatar
OyD
OyD is an unknown quantity at this point
when i did mine i just let the bumper hang from the bottom
Old Dec 23, 2002
Liro's Avatar
Back from the dead
its an easy, job, you should have no problem.
Old Dec 23, 2002
Chigga's Avatar
thanks guys.
i appreciate it...... how long does this take??? rough guesstimate is fine... b/c everyone works at different speeds!
later!
Old Dec 23, 2002
OyD's Avatar
OyD
only did it once and took about 2 hours. a half hour for the silicone to dry. the first light was a pain but after doing it, it made the second one so much easier cause you sorta know how to do it and what pressure you can use to separate the light pieces
Old Dec 23, 2002
Liro's Avatar
Back from the dead
ive cleared about 5 sets and the first time took about 2hrs, the next few times 1.5 hrs. but do a through job, i usually like to let the silcone dry indoors over night...thats to be on the extra safe side. i havent had a problem with an fogging because i have been so careful. just take your time and do it right once, cause fixing it is a pain.
Old Dec 24, 2002
Chigga's Avatar
thanks alot Liro.
well im on holidays soon, so my car will be in shambles!
Old Dec 25, 2002
Liro's Avatar
Back from the dead
no problem man, if you have any problems just post them...i cant stress being patient though, take your time and you'll be proud of the results!
brash99
Sep 29, 2015 08:42 AM
beanhead
Sep 24, 2015 12:04 PM
PunX
Sep 23, 2015 10:45 PM
shaejb15
Sep 12, 2015 01:02 AM
