Should I get the camber kit?
Old Jul 15, 2008
damion's Avatar
damion is an unknown quantity at this point
Hello all,
I just found out that my passenger rear tire worn only inner wall.
So the noise was crazy when I drive on highway.
I went to do the alignment and got new sets of tires and the guy at the shop told me
that the alignment will not fix the problem.
Our car camber can not be adjusted by alignment.
My car is not lowered or anything on suspension mode except the Progress sway bar.
Do I have to get the camber kit? if I get it which shop do I have to go to...
Thanks in advance...
Old Jul 15, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Should I get the camber kit?
If you don't have any suspension/wheel modifications besides a strut bar you don't need a camber kit.
Old Jul 15, 2008
twiztedD17A1's Avatar
twiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nice
^after a while dont the spring settle and change the stock camber? or maybe a messed up strut?
Old Jul 15, 2008
damion's Avatar
Hmm.. Then it is messed up strut?
How can I check?
Old Jul 15, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
if ur not lowered there is no reason camber would be off unless something is messed .. have u hit the rim
Old Jul 15, 2008
could be a blown shock causing tire wear. same happened to me and one tire was almost bald when the other 3 had lots of tread. but if the shop says they cant align your car, thats something different and you should find a better shop.
Old Jul 15, 2008
roll_outz's Avatar
roll_outz is an unknown quantity at this point
Yeah I would say blown shock. have it check by your mechanic..
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
