Shaking with winters
Old Oct 23, 2006
cjcruz's Avatar
cjcruz is an unknown quantity at this point
I got my winter tires put in with some 15 inch rims and I am getting the shakes. More so in the steering wheel than the car itself. The tires are Nokian
Hakkapeliitaa I bought of craigslist for 140. The shaking starts at around 110..and progressively gets worse the faster I go. Weird thing is, the shaking subsides a little bit at times when i stay within a particular speed.
Any suggestions?
Thanks Dudes
Old Oct 23, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
did you get them balanced?
Old Oct 23, 2006
cjcruz's Avatar
Yah they were balanced when the tires were mounted on the rims.
Im thinking...its either the balancing, lugs are not tight enough, or rims is bent. I hope it will be the cheaper of the bunch..
Old Oct 23, 2006
if the wheel shakes at high speed its a bad balance. just because you had them balanced, doesnt mean it was done right. lug nuts should be all at the proper torque, but that problem would affect the brakes (warp the rotors) and cause shaking while braking only.
Old Oct 23, 2006
FurBall's Avatar
FurBall is an unknown quantity at this point
If the wheel was warped, you'd get a more pronouced rumble/shake at all speeds.
Lugs nuts, probably as well.
Most likely it's the wheel weights (i.e. not balanced.)
Since putting on my black steelies with winter rubber, my car is more stable at speeds over 110km/h than on my OEM alloys + stock rubber. I found out why when I was cleaning my alloys: one of the wheel weights fell off! I have no idea how, but it did; all it left was a square patch where the weight used to be, and all that remains is the sticky tape that held the weight.
Old Oct 24, 2006
cjcruz's Avatar
Thanks guys...well I was thinking that the rims are missing or needing hub rings.
So im going to get them checked out again...
Old Oct 25, 2006
AznSaint's Avatar
AznSaint is an unknown quantity at this point
it's all already mentioned i believe... :
if it's steelies.. it may just be the balancing....
if you had aftermarket rims on.. make sure the hub rings are all off....
Old Oct 25, 2006
cjcruz's Avatar
off?....did u mean on....
I ended up getting proper lugs and another balancing...and it solved the major shaking issues (thanks Ivan from igarage.ca).
There is still a tad of a vibration..so im going to get some hub rings the next paycheque.
Old Nov 7, 2006
AznSaint's Avatar
yes. hub rings off.... you dont need 'em for stock steelies...... the hub rings are usually needed for aftermarket rims
but since your problem is fixed, it shouldnt be a problem then
Old Nov 7, 2006
rustysteel's Avatar
rustysteel is an unknown quantity at this point
I had spacers on mine for the summer rims and left them on when I put on my steel wheels/winter tires. Vibration at the same speed 110km/h or so. Took of the spacers and no problems. I should have known better but oh well, If you have spacers on, definitely take them off.
Old Nov 10, 2006
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
^^why would you need spacers, theres a large number of aftermarket wheels out there that perfectly fit our cars
mgrantaz
General
May 2, 2022 05:40 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Solo Flow
Oct 4, 2015 07:52 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
rainman15
Sep 6, 2015 11:10 AM
