Need Help: Electrical
Old Apr 15, 2005
Blkcivic's Avatar
My H.I.Ds are acting g@y lately, the passenger side won't come on ... only turns on sometimes after i switch it on/off a couple times. I'm not sure if its the hid kit, the wiring on the hid or its my car. Neone with electrical knowledge please help me out, or maybe you can direct me to a shop with experience.
Old Apr 15, 2005
1llmatic's Avatar
1llmatic will become famous soon enough
did you just install them?
if you did try disconnecting the "Daytime Running Light" Fuse
if not then it sounds like either your ballast is malfunctioning or there is a lose wire somewhere. See if you can warranty the ballast
Old Apr 15, 2005
TeLLy's Avatar
Yes, it's an Acura EL
1llmatic's got it right. For some bizarro reason I see this happening only on the passenger side of our cars - happened to me too, so I ended up swapping bulbs. Troubleshoot it by swapping ballasts, then bulbs, and if the igniter unit is separate from the ballast assembly. Definitely disconnect the DRL, it's useless to you now anyway.
I'll be in the Hamstertown area this Sunday early afternoon so if you like we can get together and check it out, just holla at the TeLLy celly.
Old Apr 15, 2005
Blkcivic's Avatar
no i installed it a while ago, i disconnected the fuse for DRL when i put them on. It was fine and everything until it stopped working and i through its the fuse, changed it and it still happens. I even went to a auto electrical place and waited a hour til they have time to check my car, stupid lights worked right when its gettin checked and they said they can't do anything until its acting up cuz it can be a numerous of things
Old Apr 15, 2005
APRboy's Avatar
APRboy is on a distinguished road
Mine used to do it when i first had them installed, but i had forgotten to take the DRL fuse, now they are ok. Since then, i think its only happened to me once or twice, but yeah, wierd how its the passenger side that does it.
Old Apr 15, 2005
Blkcivic's Avatar
I mean the hids works (sometimes), its not completely dead so yeah i'll try wht you said. And i need to aim them cuz some drivers on the road is gettin mad ...... where will you be on sunday? i can come look for you or meetup
Old Apr 15, 2005
TeLLy's Avatar
Round Linc & Upper Gage, but I'm droppin off the wifey @ Main & Gage before 11am, holla at me before then if you wanna meet up. And for the love of my poor beaten-up suspension and rims, please don't make me drive through downtown, LOL.
Old Apr 19, 2005
RIC3BOY's Avatar
RIC3BOY is an unknown quantity at this point
Yeah, I'm having trouble with the driver side HID. Anyone have any issues with that?
Old Apr 20, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
someone mentioed my drivers side was out, flicked em off (waited) and turned em on and they came back on. First time ever
Old Apr 20, 2005
vvii's Avatar
vvii is an unknown quantity at this point
So we have to take out the fuse for the DRL light after the HID installation?
I installed my 3 weeks ago and the DRL is light ON, should I take the fuse out? However, everything was working fine at the moment, will I get into the same problems if I take the fuse out for the DRL?
Old Apr 21, 2005
RIC3BOY's Avatar
I have no idea. I think I just don't have enough juice going to the ballast. I'm gonna try this aftermarket harness that hooks up to your existing harness which connects to your battery... kinda hard to explain, but hopefully it'll work out.
BTW, does anyone know how to hook up the HID so that when you turn on your highbeams, it doesn't turn off the low-beam HID?
Old Apr 21, 2005
Blkcivic's Avatar
^^^ you can't..... because we only have one reflective housing with Hi/Low sharing the same housing and lightbulb. I could be wrong but if you have hi and low beam HID on at the same time, that can seriously blind someone...hahah
P.S. my Xtec kit is a piece of ****...
Old Apr 21, 2005
TeLLy's Avatar
It involves relays and cutting/splicing either the HID harness or the OEM headlight one. Not pretty and kinda useless - trust me you'll barely see the halogen high beams working when the HID's are running.
Old Apr 21, 2005
RIC3BOY's Avatar
Oh no... I just want to avoid having the HID lowbeam turn off when the highbeams are flicked (even though I have NO highbeams). Yes, pretty much useless, but I just want to avoid hurting the bulb... since having the HIDs turn on and off rapidly would harm the bulb.
But nevermind that for now... I'm more concerned as to why my driver side keeps flickering off after like 10 minutes of driving. I'm thinking its my rad fan turning on, and having some accessories on at the same time, resulting in a slight loss of voltage to the ballast (since the ballast is supposedly really sensitive to a slight loss of voltage).
Anyone have any suggestions to that?
Old Apr 21, 2005
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
If you guys are sensitive to voltage.. buy an Optima Yellow Top.. they're deep cycle.
Also.. check to make sure your wires terminals are on the plugs properly.. because if not.. they'll result in your bulbs not functioning.. much like mine at times.. the terminals are too loose.
Old Apr 21, 2005
RIC3BOY's Avatar
Yeah I was just going to say that... Optima Yellow Top batteries... hmmmm...
Old Apr 21, 2005
NoSpleeny's Avatar
Visit Costco for your yellowtop battery needs. They're cheap there.
Or was it red top they had.......
Old Apr 23, 2005
TeLLy's Avatar
Also Performance Improvements has Yellows for like 170....
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
