transmission problem
Old Dec 28, 2004
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
this all happened within the last few days... it grinds from 1st to 2nd sometimes (manual trans).. 2nd to 3rd is ok... 3rd to 4th is tough to get into.. when in 2nd and 4th the shifter doesn't seem to be down all the way, it looks and feels like it'll pop into neutral.. and it did go from 4th to neutral a few times.
has anyone had problems like this before? will honda cover it?
Old Dec 28, 2004
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
if you are still under warranty, go ahead and take it in to get it fixed asap.. but things you could try urself is changing the tranny oil.. and there are a few other things but you'd better try a search..
Old Dec 28, 2004
BIG's Avatar
BIG
I've had 3 transmissions in my 2001....it was a 'silent recall'
Old Dec 28, 2004
PK2K1's Avatar
a "silent recall" eh? so i won't be paying for that right? how can i prove that i know about this recall, or that it exists at all? thanks
Old Dec 28, 2004
DragonAce's Avatar
DragonAce is an unknown quantity at this point
sounds like the cable needs adjusting..
Old Dec 28, 2004
Blkcivic's Avatar
3 transmissions? wht happend?
Old Dec 29, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
I had to replace my 2001 lx tranny at 35k km
honda makes **** trannys, I feel it every time I shift
they didnt make me pay for the transmission but they didnt offer to pay for my tow truck or rental car either, so cost me $130 tow and not having a car for a week, kinda felt like being crippled :P
Old Dec 29, 2004
PK2K1's Avatar
i called 2 dealerships in my area.. both service dept's claim there was no recall on 2001 civic transmissions..
they can't have it in until monday cuz they're booked solid.. did any of you get hassled for any mods? short shifter or anything that they might try to claim could have an affect?
Old Dec 29, 2004
DragonAce's Avatar
short shifter "could" inadvertently have an effect
Old Dec 29, 2004
astigmatik's Avatar
astigmatik is an unknown quantity at this point
try changing the tranny fluid and cleaning the linkages to the tranny. Honda will chrge $70 taxes in for this service.
Old Dec 30, 2004
PK2K1's Avatar
proof of this "silent recall" anywhere? two dealerships claimed there was no recall
Old Jan 3, 2005
PK2K1's Avatar
alright, so i dropped off the car at castle honda today... at first they said i had to go home and put the stock shifter in (they thought i had a short shifter).. but really it's the stock shifter with like an inch cut off and a momo **** (i know, it's pretty ghetto). anyway, they said they have to take out the centre console and look around and stuff to check if it's covered under warranty.. i have a feeling they're gonna try to **** around with me.. so if any of you guys know where i can find any info on this "silent recall" or what exactly voids a warranty, please help me out.
Old Jan 3, 2005
SiG's Avatar
SiG
knowing honda, they'll say you cutting your stock shifter an inch is the reason for this and that its now your fault
Old Jan 4, 2005
FAT_MAN's Avatar
I beat anorexia -QBoi
FAT_MAN is an unknown quantity at this point
you may have blown a sincro
my buddy did that in his rx7 and his integra
Old Jan 4, 2005
PK2K1's Avatar
ok, well they called today and said that i cut the shifter and welded my new shifter on (they're idiots it's a momo with set screws).. and they said i modified the cable underneath, which i didn't touch.. so they want to charge me $590 to get a new shifter and cable and bushings in there to get it back to "stock" (it is stock, except the 1 inch cut)... then they say they'll check the tranny.. **** that.. so which dealerships actually did the work under warranty? i'm gonna go pick up the car and take it to a tranny place to get it looked at, i don't think it's a major problem anyway.
Old Jan 4, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Wow, are they really that dumb, or do they really think you are? Freakin retarded. If you need to borrow a stock shifter assembly let me know, you may then be able to take the car to another dealership to honour warranty, assuming you have extended or something. If you want to try changing tranny fluid (not hard at all) there's an excellent DIY on the site. I found my tranny shifted smoother after I changed mine - you never know, that might be all you need.
People on this site have had post-service problems with places that used machines to flush the tranny then replaced all the fluid. So make sure if you do try changing the fluid (by yourself or at a shop), don't flush it out, just drain what will pour out when the drain bolt is pulled, then replace the fluid. Good luck.
Old Jan 4, 2005
PK2K1's Avatar
is the transmission covered as 3 year 60,000km or 5 year 100,000km?
i took the car into a tranny place and they looked at it and said it's the 4th gear synchros.. and that they'd like to change them all (b/c the 2nd gear ones are going too).. quoted me 1200-1500. if the tranny is the 5 year 100,000km i'm still covered.. in that case, Telly i'd like to borrow your stock assembly and take the car to another dealer.. but how hard is it to swap those parts?
Old Jan 4, 2005
Civic2001Silver's Avatar
Civic2001Silver is an unknown quantity at this point
I think it should be covered under the 5-year 100000km as the 3 years is bumper to bumper. So I would put it back to stock and try another dealership.
Old Jan 4, 2005
TeLLy's Avatar
Shifter assembly takes 15-20 depending how hard it is to pull your centre console - there's an excellent diy here. If you wanna borrow the assembly just shoot me a pm.
*edit the warranty appears to be 5 years 100 000km....from the Honda site:
http://www.honda.ca/Honda/YourHonda/...verage.htm?L=E
Old Jan 5, 2005
I doubt they'll admit it, but if you drag your warrenty civic in, and every time you put it in a D it just revs as if its in P or N. Thats when they'll swap your tranny.
I think it falls more under 100k powertrain then a recall
Old Jan 11, 2005
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Those bastards...
I'm on my 2nd tranny also, there was a service bulletin on 01 5-sp trannys. Look on edmunds.com. they are such crooks. This has been an ongoing issue with my car as well. Fist I had the bushings replaced...a few months later they opened it up and replaced a few things. finally they totally rebuild my tranny. 30000kms later it makes a whining noise (becuse they didn't properly shim the differential bearing) and it grinds int 3rd gear just about every time. Between the transmission and the suspension issues, this car has been a real disappointment.
Old Jan 11, 2005
APRboy's Avatar
APRboy is on a distinguished road
yeah its crazy how the 01s had a lot of probs and then in 02, nothing, they fixed everything. Never buy the first year of a new model change.
Old Jan 11, 2005
ArtIntown11's Avatar
The Original F*ckin Angry Armenian
ArtIntown11 has a little shameless behaviour in the past
I agree with that 100% there are just too many freakin bugs. Honda is going down the drain and Scion is just dominating, well around here anyways.
Old Jan 12, 2005
PK2K1's Avatar
thanks for the replies guys... i was on the edmunds website. i can't find anything about our cars and a transmission problem or recall. it would be nice to have a print out to have for when i go to honda next time.
Old Jan 12, 2005
nickm748's Avatar
Any one have ne problems with 04 trannys?
Old Jan 13, 2005
CoupeStylz's Avatar
Si(R) killer # 1
pk2k1
look here http://www.edmunds.com/maintenance/r...step2.9.Honda*
Old Jan 13, 2005
PK2K1's Avatar
CoupeStylz, thanks a lot
#143 sounds most like what's going on. Using the bulletin number and bulletin date is there any way to get more information?
MajTom
Jun 2, 2015 11:48 AM
Schneiderman
May 24, 2015 01:14 PM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
markp94
Apr 30, 2015 09:19 PM
