Random Technology Cat broke off @ the drag strip
Old Jun 12, 2004
Macfay's Avatar
Macfay is an unknown quantity at this point
Angry Random Technology Cat broke off @ the drag strip
I did custom exhuast at Midas last summer...they told me that I don't have to worry about the exhuast anymore cuz its stainless steel and they did "good weld"...anyway...its bad...really bad...
damn...don't wanna explain it...just wait for APRboy upload the pics and you guys will understand...
EDIT: Special Thanks to Bruno, Owen and Steve!!! They help me a lot for the entire night...finding tools, jacking up my car, pulling out the exhuast and wait for the tow truck with cold weather...etc...1000s "thank you" to you three!
EDIT again: found to be my random technology cat got broken off...
Old Jun 12, 2004
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
Broken off? How did your exhaust break off?
Old Jun 12, 2004
APRboy's Avatar
APRboy is on a distinguished road
Yes, very bad night indeed. At least you beat your personal best Macfay! Too bad it cost too much afterwards...
Old Jun 12, 2004
APRboy's Avatar
here are a few pics...
ID:	30906   Click image for larger version
ID:	30907   Click image for larger version
Old Jun 12, 2004
APRboy's Avatar
a few more...
ID:	30909   Click image for larger version
ID:	30910   Click image for larger version
Old Jun 12, 2004
APRboy's Avatar
Macfay, any time bro. Btw, who's Steve?
Old Jun 12, 2004
Mr.Modify's Avatar
wow that's ****ed up...the whole exhaust looks like it fell!
Old Jun 12, 2004
Macfay's Avatar
oh ... Steve...was that the other guy from LAC who works for the dragway...the one who drive 4x4? May be I forgot his name....
I'm going to call Midas now...
Old Jun 12, 2004
NoSpleeny's Avatar
Let us know what happens!
Old Jun 12, 2004
APRboy's Avatar
Oh yeah, Steve, i forgot his name. Good guy! Post up what happened at Midas Macfay. Hope your rental car doesn't give you any problems. I'll post up some nicer pics before this whole mess started in the London Peeps section.
Old Jun 12, 2004
Macfay's Avatar
damn...Midas told me that its not the weld they made broke off, it was actually the original connection between the inlet and the cat got broken off...at least this is what I've been told.
I will go to Midas on Monday and find out the truth as I'm in Toronto right now.
I also call and email Random Technology to see about the warrenty thing on their cat. But since there was an alternation on the original pipe(which I cut and extended their pipe to avoid the rubbing against the front sway bar), I'm not sure if I can still claim warrenty on it...damn...
I hope everything goes fine...
Old Jun 12, 2004
APRboy's Avatar
Bull crap! They should fix it regardless, they welded it, not the original connection. They just don't wanna cover it.
Old Jun 12, 2004
Macfay's Avatar
actually...I took some pics before heading to toronto...and I just zoom into the photos and found out that Midas didn't lie to me...
the section which they cut and weld was further away from the cat...therefore, the section which broke off was the weld that random technology did, so i think its the manufacture defect...
I will take more pics on Monday morning and find out the truth...
Old Jun 13, 2004
APRboy's Avatar
This sucks Macfay, i hope you get things resolved asap.
Old Jun 13, 2004
vvii's Avatar
vvii is an unknown quantity at this point
good lcuk, and keep us up to date ....
Old Jun 13, 2004
Macfay's Avatar
here are the pics that I took on Saturday morning...
http://community.webshots.com/album/152395153WAXSgl
its NOT the weld made by Midas which got broken off...
Old Jun 13, 2004
opto_isolator's Avatar
Any modifications you made to your car besides exhaust? Looks like the cat got so hot that it caused failure of the welded joint, that would be my guess. Cats usually don't get extremely hot (ie normal op temp is usually around 2500 degrees) unless you are running pretty rich, which sometimes allows gas to burn up in the cat, causing problems....I know running SF's kit will cause you to run rich - just curious....
Old Jun 13, 2004
R1Style's Avatar
sh!tty luck man... hope everything works out.
BTW... what did you run?
Old Jun 13, 2004
Macfay's Avatar
all of my mod are just basically bolt-on...just I don't think it will get upto 2500degrees...
my last run before the cat broke off was 15.937....
Old Jun 13, 2004
Dasica's Avatar
Dasica is an unknown quantity at this point
Sorry to see that MacFay.
Old Jun 14, 2004
Ummm, that's how a cat works - it uses a platinum catylist. When it heats up (via the exhaust gases passing through it) - the catylist than starts to convert the NOx and other gases. This causes it to get hotter, up to around 2500 degrees....If there is too much gasoline vapor in your exhaust, it will get hotter, and cause cracking and failure.
Old Jun 14, 2004
Macfay's Avatar
so you think my car is running too rich before the cat broke?
Old Jun 14, 2004
If you were running a turbo or nitrous possibly - but since you are just running bolt-ons, it could be just poor quality worksmanship on their behalf.....
Old Jun 14, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
wait.. extended the pipe? did you do that by welding too? and is that the area where it broke?
Old Jun 14, 2004
Macfay's Avatar
NO
I have more pics uploaded into my gallery...
I took this pics while my car is in the air...
I called up Random Technology and they told me to ship the damaged cat to them and they will determine if I can claim warrenty on it...but I have to pay the shipping...
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
loosescrew84
Aug 26, 2015 06:54 AM
WaryDriver
Aug 8, 2015 05:08 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
