shock question
Old Mar 18, 2004
sictoy's Avatar
sictoy is an unknown quantity at this point
Question shock question
Keep in my mind that my car is lowered, I can fit two fingers between the wheel and the wheel well.
If one person sits in the back I can't even fit in one finger, so Im assuming that this means my shocks have blown. However I dont have the cash to buy koni's or kybs or tockios and I obviously will not buy oems shocks becasue they will blow again. So I wanted to know if those perfomance shocks that are sold at Canadian tire would solve the problem of my rear dropping so far and if they will last longer then oem.
Thanks for the help
Old Mar 18, 2004
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
The springs are used to control the amount your rear drops... and how far your car goes up and down when you hit a bump.... furthermore.. it controls how far your car nose dives in hard braking.
The shocks are used to control the rebound of the bouncing of the springs... the shocks are dampers when you hit a bump and your springs are bouncing like mad. Furthermore.. it controls how MUCH your car nose dives in hard braking.
If your car's *** end is sagging when people are in the rear... there's nothing wrong with your shocks. That's your springs giving way. When you hit bumps and your *** end won't stop bouncing up and down... and it looks like a french maid ****ing.. then we have a problem with your shocks.
Hope that helps.
Old Mar 19, 2004
AznSaint's Avatar
AznSaint is an unknown quantity at this point
if there's no finger gaps when your friends sits in the back seat, it doesnt mean your shocks are blown. it just means that there is weight in the back area........ *hence, friends sitting in the back sit
ways to know if your shocks are blown is if the rides suddenly feels a lot rougher... or check if the shocks are leaking, if you know how to check.
if you have aftermarket springs.. without aftermarket shocks... it'll feel rougher then the stock springs b/c of the spring rates.
Old Mar 19, 2004
Liro's Avatar
Back from the dead
is this your first time dropping a car? yeah, these guys are dead on...your shocks sound fine...what kinda springs you put in?
neuspeed or h&r sports? just curious...lower spring rate will cause what you're talking about
Old Mar 19, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
What kind of spring are you using, and i don't think your shocks is blown
Old Mar 19, 2004
Liro's Avatar
Back from the dead
didnt i just ask this questions? pure PW....hahaha...im on to you....
Old Mar 19, 2004
sictoy's Avatar
the car is on Tom Motorsport coilovers
Old Mar 19, 2004
Liro's Avatar
Back from the dead
dun know much about them....hmmm....still thinks you're shocks are fine
Old Mar 19, 2004
sictoy's Avatar
i have another question, what do you do if the spring is not sitting properly? How can I fix that?
Old Mar 19, 2004
MONTREALCIVIC's Avatar
MONTREALCIVIC is an unknown quantity at this point
the best way to see if the shocks are blown is to see if any oil is leaking from the midle of the shock where ther rod is exposed. i hope this description is clear enough.
Sep 26, 2023 06:44 PM
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
Tedverseti
Apr 23, 2020 01:45 PM
Mr.Beefy
Aug 12, 2015 04:39 PM
viperGTS
Jul 27, 2015 08:40 PM
