reset check engine light?
Old Nov 18, 2003
R2FRESH's Avatar
R2FRESH is an unknown quantity at this point
Exclamation reset check engine light?
how do u do it? searched DIY but only SRS, the check engine is supposed to be easier, hold button, turn on car or something like that? help plz!
Old Nov 18, 2003
GuSTo's Avatar
GuSTo is an unknown quantity at this point
just pull the fuse for the ECU under the hood
plug it back in after 10 minutes and it SHOULD go away depending on what the problem is
if it comes back you should take it somewhere to get the engine code read so you can fix the problem
Old Nov 18, 2003
Macfay's Avatar
Macfay is an unknown quantity at this point
or you can disconnect the negative terminal from the battery...
Old Nov 18, 2003
R2FRESH's Avatar
thanks, greatly appreciated,
welcome back gusto! long time no talk
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
