SOHC or DOCH?
Old Jun 9, 2003
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
SOHC or DOCH?
Are our cars SOHC or DOHC Vtec? Whats the difference?
Old Jun 9, 2003
cambo's Avatar
I wish I was asian
SOHC
Old Jun 9, 2003
Voiceofid's Avatar
End Bringer
SOHC stands for single over head cam
it means the engine has only one cam rod to open/close the exhaust and intake valves
DOHC means dual overhead cam
which is basically one cam for intake and one came for exhaust. dohc are usually more adjustable due to the ability to able to tune the intake and exhaust timing the way you want seperately. unlike sohc, which must adjust intake and exhaust timing at the same time
Old Jun 9, 2003
R3DL1N3's Avatar
in other words DOHC is better. 2 cam rod, 2 cam gear.
Old Jun 9, 2003
ooooh i get it. thanx
Old Jun 9, 2003
ChEe12iO's Avatar
ChEe12iO is an unknown quantity at this point
dohc is not necessarily better. sohc engines can spool up faster because there is less valve train to move unlike a dual overhead cam. potential is higher with dohc because of what was said above... ability to tune the intake and exhaust cam separately....
Old Jun 10, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
can you rebuild a sohc into a dohc? or is that impossible?
Old Jun 10, 2003
Master's Avatar
Banned by Admin
I'm not totally sure but I highly doubt it, plus if you could it would cost so much money it would be cheaper to swap in a DOHC (K20)
Old Jun 10, 2003
OMega's Avatar
OMega is an unknown quantity at this point
Realy? I thought the spool up would be the same if not slower due increased rotional mass of the single cam. The fact the work being done is beign halfed by dohc also should make it faster? Swaping in a different ex. cam for turbo on a dohc with tuning would over came any differances. I don't know.... all do know is my sohc gets better milage then my dohc engine.
Old Jun 10, 2003
S2000man01's Avatar
O RLY
There are some that believe the SOHC can spin to a faster RPM, however, that's a battle that's still being fought.
As for rebuilding a SOHC to be a DOHC, you'd have to swap the head. IF the DOHC head will fit the SOHC block.
Old Jun 10, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
you can't fit a DOHC head on an SOHC block.
Old Jun 10, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
What? Anyone understand this?
Old Jun 10, 2003
S2000man01's Avatar
O RLY
Tell that to black99vtec.
Old Jun 10, 2003
Zzyzx's Avatar
Autocross Junky
I think he has his logic a little backwards. How can 1 cam be heavier then 2?
Old Jun 10, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
the 1st 2 points!
OMega's trying to say the total inertia of a SOHC system would be more than a DOHC system, meaning the engine RPM will increase at a slower rate. (don't think so)
The 2nd point about the work being 1/2 (1 CAM operates intake & the other exhaust) doesn't make any sense, as far as the rate of increasing engine RPM
i don't understand the 3rd point & what the turbo has to do w/ the topic.
Generally SOHC motors have their CAMs tuned for efficiency, rather than power, which is why a SOHC gets better mileage than a DOHC (DOHC motors are tuned for power). If you tuned a DOHC motor for fuel efficiency, it would probably be more efficient...
Old Jun 10, 2003
liljoe's Avatar
liljoe is an unknown quantity at this point
I could be wrong, but isnt the Hybrid a DOHC tuned for efficiency??
Old Jun 10, 2003
OMega's Avatar
Mass for mass the sohc is going to be heavyer because of all the lobes. I don't think you could get away with making a lighter cam becuse of all the stress being place on the sohc.
I'm looking at cams as a pully system... could be the wrong way to go about it. From what I rember on b-series cam gears are smaller then the sohc's. Well if the ratio works out right less energy is being used to rotate the cams. Like I said this could be the wrong way to look at it.
The turbo parts was for ChEe12iO "spooling up". Now as I look at it I think he was talking about how fast the rpm increase.
Old Jun 11, 2003
Jeremy's Iron
Stock for stock, a DOHC will own a SOHC. Even if you tuned both of them (and this is for the argument on whether or not the SOHC can get RPM's up faster), the DOHC would still be better in the long run.
At least I think that's right..
Old Jun 11, 2003
pbfoot's Avatar
lol...instigator!!!
Old Jun 11, 2003
§C§H§O§C§O§B§O
does black99vtec have a dohc head on a sohc block?
Old Jun 11, 2003
Zzyzx's Avatar
Autocross Junky
No one knows for sure, not even him.
Old Jun 11, 2003
§C§H§O§C§O§B§O
lol...all hope gone down the drain for me...lol
o well, i stick with the sohc, i need the mileage anyway.
Old Jun 12, 2003
MonteCarlo SS's Avatar
MonteCarlo SS is an unknown quantity at this point
I wonder if a first gen would have a pushrod engine?????
that might be neat to fix up.... pushrods rule for torque!
Old Jun 12, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
what ever happened to black99vtec, havent heard from him in a while, or is he still finishing up the swap of that sr20det into his vic
Old Jun 12, 2003
adnmoh1's Avatar
adnmoh1 will become famous soon enoughadnmoh1 will become famous soon enough
best way to tell the difference. DOHC and SOHC is like comparing chocolate and ****. (pl prove me wrong if you guys dont think so).
Old Jun 14, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
have you seen his user profile?
Old Jun 14, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
SOHC or DOCH? (from the title)
is that sohc or Dueshe? i think you should do the later.
jk
dohc will be better for tuning
Old Jun 15, 2003
artychris's Avatar
artychris is an unknown quantity at this point
ha ha ha
jk
I was about to say the same thing.
I'd say keep the SOHC until you make some good money then put in a K20A or K20A2.
I know that if I had one in my engine bay, then I wouldn't be able to eat properly.
The D17A2 will definetely serve you well for gas mileage.
Old Jun 15, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
A single cam will have more mass than one of the cams from a DOHC engine. But it will have less than the two smaller cams together. So total cam mass is less in a SOHC engine. That would be anadvantage to SOHC but it may not be a performance advantage...
Is the K20a2 DOHC how about the engine in the NSX or s2000? These cars are geared towards high performance. If SOHC was better for performance common sense would dictate that those engines would utilize that design.
danace99
Oct 17, 2015 02:51 PM
Amulon
Aug 18, 2015 11:03 AM
jwalkerck1
Aug 17, 2015 10:03 PM
darwin-t
Aug 15, 2015 10:51 AM
Bounddyy
19
Jul 20, 2015 02:42 PM
